Intel® Optane™ Memory
Intel Optane install
LennartII
Trying to install Optane I think I'm stuck somewhere in the middle.
Mobo Asrock B365M-HDV (1151, intel optane ready)
Processor: Pentium Gold [email protected]
Optane 535 series M.2 240GB
Intenso SataIII SSD 120GB
Both drives are GPT
Bios is set to intel optane with raid, without raid setup/paired disks.
In the optane memory management It says no paired disks. I try to pair them there but that doen't seem to work.
Pairing them in bios i guess would force me to reinstall windows (which is installed on the M.2.
Was i wromg to install windows on the M.2 and should I install it on the SSD instead? Or should I "just" pair the disks in the bios and reinstall windows. Confused because I thought that optane wouldnt work with raid.
I also get a message somewhere that I have the wrong chipset?
Thanx in advance for any help/ideas.
n_scott_pearson
You do not have any Optane devices!!
You have an old Intel 240GB M.2 SATA SSD and an Intenso 120GB 2.5" SATA SSD.
So, what is it you are trying to accomplish with these? The only thing you could do is put them into a RAID0 array, but understand that you would have to reinstall everything, including Windows 10, to do so.
Hope this helps,
n_scott_pearson
Please download and run the Intel System Support Utility for Windows and save the report to a file. Then, using the Drag and drop here or browse files to attach dialog below the edit box, upload and attach this file to a response post.
LennartII
Thank you ! Here it comes. Appreciate your help!
n_scott_pearson
Hope this helps,
