Intel® Optane™ Memory
Optane Memory Status
Rids_03
Hello, could anyone help me to enable the optane memory status. Currently it is disabled and I can't enable it because it seems it is locked. I have attached the screenshot for your reference.
LeonWaksman
According to the SSU report, there is no Optane Memory Module installed on your computer. The only drive you have is 2TB Seagate HDD. So, you can't enable Optane acceleration.
Leon
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
Rids_03
please find the scan result in the attached file.
LeonWaksman
Leon
