Intel® Optane™ Memory
1391 Discussions
Mensaje de error: intel optane(tm) memory pinning no se puede cargar el archivo dll "iastorafsserviceapi.dll". No se puede encontrar el módulo especificado. (Excepción de HRESULT: 0x8007007E).
LQuij2
Mi computadora es nueva de hace unos 4 o 5 meses nomas la adquiri y me sale estos mensajes de la memoria optane cada rato, cad que habro mis documentos.
Ayuda porfavor. Please
JosafathB_Intel
Hello LQuij2,
Thank you for contacting Intel® Memory and Storage support.
Please take into consideration that our support is provided in English only, and we are machine-translating your message, meaning that we may lose the true meaning of the question.
As we understand, you need assistance with an error related to your Intel® Optane™ Memory. If we infer correctly, we will appreciate it if you can provide us with the following information:
• Your system configuration, including manufacturer, model, and part number of all your system components and a copy of the SSU logs obtained from the system that the Optane is connected.
1-     Go to https://downloadcenter.intel.com/download/25293/ and download the software.
2-     When finished downloading it, open it.
3-     Attach the file obtained to your reply post.
• Please, let us know the version of the Optane software that you have installed in your system.
• A screenshot of the “Disk Management” showing all the storage devices. To access the disk manager, you can choose from the following two ways:
# 1: Open it from the Quick Access Menu.
o Right-click the bottom-left corner (or Start button) on the desktop to open Quick Access Menu, and then choose Disk Management.
# 2: Access Disk Management via Run.
o Use Windows+R to open Run, type “diskmgmt.msc” in the empty box, and tap OK.
We will be looking forward to your reply, including this information.
Josh B.
A Contingent Worker at Intel®
LQuij2
Listo, Aqui estan los datos que me pidio.
JosafathB_Intel
Hello LQuij2,
Thank you for your reply.
Based on the logs and information you provided, your PC is a Dell* PC and does not have an Intel® Optane™ Memory installed. We advise you to contact your OEM (original equipment manufacturer) to confirm that your system came with an Intel® Optane™ Memory installed from the factory, and the recommended configuration of the BIOS and software needed to use the Optane acceleration.
Please let us know the recommendations given by the Dell* support since it may help some other community members in the future.
Best regards.
Josh B.
