Intel® Optane™ Memory
Optane error 0xA008002e
BNyst
I recently installed 32GB of Optane memory in an Acer X4650G and configured it. It worked fine last week, but today I'm getting an error code 0xA008002e. This code is not listed in any of your documentation that I can find. The Support Assistant indicates that the drivers and firmware are up-to-date. The system seems to be running OK, so I'm not sure how critical this error is. I've attached the Detailed System Report. What do I need to do here?
Brian
Hi Bnystrom,
Thank you for posting in the Intel® communities.
The error code 0xA008002E doesn't appear in the current documentation as you mentioned, and I haven't found any report of this error code. However, I can see from the report attached that the Intel® Optane™ Memory is still paired with your drive, so it should still be working.
My recommendation would be to go to the Intel® Optane™ application and disable the module. Once it's disabled, please uninstall the application and then make sure to re-install it using the latest version.
You can find the Intel® Optane™ application in the following sites. You can use either the Intel® RST application or the Intel® Optane™ application, both work to setup the module. You can use the same one that you currently have:
Once it is installed, open it and enable the module again.
Let me know if you get the same error after re-installing the application.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
Hi Bnystrom,
Have a nice day.
Diego V.
BNyst
Thanks Diego. I wasn't able to disable the Optane memory because the Intel Optane application wasn't loading properly. However, I was able to uninstall it and install the new version of RST, and everything seems to be working fine now. I guess the app had gotten corrupted somehow.
Best Regards
Brian
