Intel® Optane™ Memory
Ram for my board
OGSpaceTime
im not sure where how to post this
will this ram : Mushkin Redline  Lumina- DDR4 RGB Gaming  DRAM 64GB (2x32GB) 3600MHz PC4-28800 CL-16 288-pin 1.4V
work well for this motherboard:
MSI PRO B660M-G DDR4
I'm hesitant to make a purchase. I want to max out the board and not worry about it any more...
AlHill
You need to consult with MSI regarding memory support and compatibility for their board.
Irwan_Intel
Hello OGSpaceTime,
Thank you for the posting in Intel Ethernet Communities.
Kindly note, your inquiry is related to OEM manufacturer, and we suggest you reach out to MSI to double-check if the RAM is compatible.
We will proceed to close this thread. Please open a new thread if you have further questions or concerns.
Irwan_Intel
