Intel® Optane™ Memory
1401 Discussions
Rendimiento del equipo bajo usando python
magoazul515
Al usar el equipo que poseo, ejecutando un programa de Python 3, la ejecución se demora mucho en comparación con mi anterior PC Hp de 8 GB de memoria RAM. El equipo DELL que poseo tiene una memoria física total de 24 GB. No se si estoy configurando el equipo de la forma que no es o estoy omitiendo algún paso para lograr el mejor rendimiento de mi equipo. Necesito que me ayuden con esto.
Gracias
LeonWaksman
Hi @magoazul515
You wrote this post in Intel Optane Memory section. Do you have a Intel Optane Memory module in your laptop?
In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
magoazul515
Le adjunto ejecución del análisis de SSU. Espero su respuesta.
Devi_Intel
Hello magoazul515,
Greetings ~
Thank you for reaching Intel® Optane™ Memory community. From the SSU log, we have noted that there is no Optane memory usage in the system. Your system is using NVMe 2400A NVMe Micron 512GB storage.
Since your system includes Dell and Micron storage components, we recommend seeking assistance directly from the original equipment manufacturers (OEMs). They will be able to provide the most accurate and specialized support of the system. Please contact Dell and Micron support teams for further assistance.
Thank you & Best Regards
Devi
Devi_Intel
Hello magoazul515,
Greetings ~
We are following up to find out if you were able to complete the actions we previously recommended. Your feedback is important to us
Devi
