Intel® Optane™ Memory
1403 Discussions
Several Intel Optane modules in one computer?
SNti
I have two M.2 ports, can I buy two Intel Optane and double speed? They will work in RAID?
Hi StudioNti,
We understand your concern regarding the Intel® Optane™ Memory.
We would like to let you know that you can not use 2 modules at the same time on the same system because it is not supported. The Intel® Optane™ Memory is designed to work only with a SATA Boot drive
You could set up a RAID with the 2 Optane™ Memories only if you use them as a storage device. However, please bear in mind that we do not support the usage of the Intel® Optane™ Memory as a storage device.
For more information you can check the following article https://www.intel.com/content/www/us/en/support/articles/000024018/memory-and-storage/intel-optane-memory.html Frequently Asked Questions for Intel® Optane™ Memory.
Please let us know if there is something else we can assist you with.
Junior M.
