Intel® Optane™ Memory
1391 Discussions
Soporte para poder instalar una Memory Optane 32GB en motherboard Z390 Code Saludos
AGali3
DiegoV_Intel
Hi AGali3,
Thank you for posting in the Intel® communities.
I understand that you need help to configure the module in your system, however in order to better understand your system environment, please download the Intel® System Support Utility (SSU) from the following site and run the full report. This report will include all details of your system. Please export the data in a text file and share it in your response: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Additionally, please open Disk Management and take a screenshot of the window. To open Disk Management press the Windows* key + x, and then select the Disk Management option from the menu that will appear.
Finally, please run the following commands in the Command Prompt to take another screenshot:
  1. Open the Command Prompt as Administrator.
  2. Run the command diskpart.
  3. Run the command list disk. Please take a screenshot of this output.
I will be waiting for your response.
Have a nice day.
PD.: The community support is only provided in English.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi AGali3,
Have a nice day.
Diego V.
DiegoV_Intel
Hi AGali3,
I would like to know if you have any updates about this.
Diego V.
DiegoV_Intel
Hi AGali3,
If you have any updates, feel free to share them here.
Diego V.
