Intel® Optane™ Memory
1396 Discussions
The Optane software does not recognize my Z690 motherboard
Herr_Heusers
as soon as I try to install the Optane Memory software, the program tells me that Intel Optane must be with a motherboard with chipset series 200 or newer, which I have with a Z690. I have the latest chipset driver and also the BIOS is reflashed with the latest version. I cant get it Installed, I hope someone can help me with this.
Best Regards
Herr_Heusers
AlHill
What is your bios SATA mode set to?
Herr_Heusers
It's set to AHCI, but I can't select it any other way, that's the only option.
AlHill
Then your motherboard does not support optane.
Herr_Heusers
But then i don't understand why it is stated in the datasheet that it is supported.
Should I rather ask NZXT support then?
AlHill
I would certainly ask the motherboard manufacturer about their bios support.
