Hi Intel Team,
I have Intel Optane Memory 32GB. I was using Intel Optane Memory with Secondary HDD. It was pretty fine.
After fresh installation I can't see my optane drive any more. I forgot to disable it. I tried cut relation between hdd and optane drive. And i couldn't initial them together.
My Intel Optane Memory doesn't appear in Windows OS, disk management, cmd diskpart and bios rst section.
I can see it(Intel Optane Memory Device) in BIOS Storage Section.
1 解決方案
Check if have in Bios Add-inn Config (Advanced > Devices >Add-inn Config) . In this section you can disable the enablement.
Leon
連結已複製
1 回應
