- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I was installing optane and I got this error (0xA0000002) please help I wanted to boost my hard disk but ended up with this error
Link copiado
15 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
Thank you for contacting Intel® Memory & Storage Support.
As we understand, you need assistance with your Intel® Optane™ Memory. If we infer correctly we will appreciate if you can provide us with the following information:
• The SSU logs.
1- Go to https://downloadcenter.intel.com/download/25293/ and download the software.
2- When finished downloading it, open it.
3- Attach the file obtained to your reply.
• A screenshot of the “Disk Management” of windows showing all your HDDs and partitions (this to have a better view on how your HDD is detected by the OS)
• A screenshot of the error that you are receiving.
We will be looking forward to your reply including this information.
Josh B.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I have sent the info down below also new volume d is intel optane
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
Thank you for your reply.
In order to further assist you we will appreciate if you can provide us with the following information:
• A screenshot of the “Disk Management” of windows showing all your HDDs and partitions including the bootable drive ( C: )
• We will like to know the drive that you want to accelerate using your Intel® Optane™ Memory.
Josh B.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
i want to accelerate the 4TB disk (disk 1)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
• A screenshot of the “Disk Management” of windows showing all your HDDs and partitions including the bootable drive ( C: ) this in order to have a better understanding of your current configuration.
Josh B.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
In order to further assist you we will appreciate if you can proceed with the following troubleshooting:
• Please create a verified backup of your information.
• Disconnect the disk 0 (the Dynamic disk that the OS refers as “M:”) from your system.
• Try to boot to your OS.
• In case that you are able to boot to your OS, access to the Optane software and try to accelerate you HDD and let us know the results.
• If you are not able to boot to your OS that means that part of the information necessary to boot your OS is locate on the Dynamic drive and you may need to reinstall your OS.
We will be looking forward to your let us know the results.
Josh B.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
thank you that worked!!!!!!!!!!!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
Based on the “Error Codes and Messages While Enabling and Disabling Intel® Optane™ Memory” article (https://www.intel.com/content/www/us/en/support/articles/000024113/memory-and-storage/intel-optane-memory.html):
Generic Error
Error code: 0xA007000D
Visit the Intel® Optane™ Memory support page for help. (0xA007000D): Generic Error
This error could occur if there’s data on the memory module the user interface/application couldn’t erase during the enabling process. Potentially system files.
Action: Back up or move all needed files to the SATA disk that may be on the module. Format the Intel Optane Module. Once complete, attempt to enable system acceleration again.
As part of the troubleshooting, we need you to follow the “Removing Partitions with Microsoft DiskPart” guide using the “Clean all” command in order to remove the partitions and the volume information from your Intel® Optane™ memory.
Intel® recommends that a full and verified backup of data be performed before attempting to apply this process; see "The Importance of a Backup Solution" at
http://www.intel.com/content/www/us/en/support/server-products/000007914.html.
We will be looking forward to your reply let us know the results.
Josh B.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
This is just a friendly reminder that your case remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
Thank you for having contacted Intel® Technical Support.
I was reviewing your community post and we would like to know if you need further assistance or if we can close this case.
We will be looking forward to your reply.
Josh B.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
thank you you can close the support ticket
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello SRedd23,
As per your consent, this case is now close if you need further assistance please do not hesitate to contact us again.
Josh B.
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
