Intel® Optane™ Memory
1391 Discussions
What to replace optane memory in HP Omen desktop 880 with bootable 500G M.2 SSD drive. According to BIOS warnings OS is spread over 16gb M.2 optane drive and SATA drive. Can this be done?
DPort9
n_scott_pearson
Try downloading the app from the MS App Store and running it.
AlHill
If you plan to replace the optane, no problem. Just disable the optane, and remove it.
Doc
DPort9
Disabling it in Bios provides somber warnings about total loss of data on Optane drive and sata drive. Installing the new M.2 driver renders the computer unbootable looking for an OS. Changing boot options in BIOS results in same message. Somehow, I have to make the new SSD drive bootable.
n_scott_pearson
'Disable' as in go into the RST/Optane Console app and disable the Optane cache. Once this is done, add data will be persisted on the HDD and the Optane not used at all. Then you can remove it.
DPort9
*driver should be drive
AlHill
Yes, I should have said disable it in the APP.
Doc
DPort9
Might have found one of the problems, there is no RST console app installed. Nothing in services, programs. Hp driver history says Intel Rapid Storage technology driver installed 10 months ago. I have not seen it. BTW thanks for being available at this time of night!
DPort9
Tried reinstalling the driver. Returned a message, "No longer applicable"!
n_scott_pearson
DPort9
OK, downloaded from the App Store. Installed and disabled optane. Rebooted, came back up, praise the Lord. Tomorrow, I will install the new drive and see if I can make it bootable. I'll use the other 2 TBs for storage. Thanks for all your help.
