Intel® Optane™ Memory
1391 Discussions
dobrý den, omlouvám se že otravuji s takovou hloupostí ale nemohu najít stažení Intel® Optane™ Pinning Explorer Extensions. potřebuji jej stáhnout protože jsem dával Windows do továrního nastavení a program se odinstaloval. děkuji
JStan26
LeonWaksman
During validation, an issue was encountered in the Intel RST version 16.7 driver. This results in the system staying in C0 and not able to enter C10 core idle power state. This could also result in an increase in Windows File Explorer CPU utilization.
This is related to the Intel Optane Memory Pinning Explorer Extensions, which when installed, enables pinning through Windows File Explorer.
To mitigate the impact of this issue, these extensions were removed from the default installation with the Intel RST 16.7 driver package on a clean OS installation.
So, if you have Intel RST version 16.7, better do not install this extension. By installing the extensions with the Intel RST version 16.7 driver the system will stay in the C0 core idle power state and could result in increased CPU utilization.
For complete information see here: https://www.intel.com/content/www/us/en/support/articles/000030517/memory-and-storage.html
Leon
LeonWaksman
Leon
