Intel® Optane™ Memory
1391 Discussions
i ask you to please answer this POST Optane memory Question
cmimf
If i use this BIOS settings sata controller Intel RST Premium With Intel Optane System Acceleration (RAID) ´s mode doesn´t happen what i am going to write in this POST ?
what i ask if doesn´t happen, is if it doesn´t shows the following message: Message from HDD Regenerator PERFORMANCE RECOMMENDATION! The system has detected SATA controller, working in AHCI mode. For a better performance, it is recommended to reboot the computer before starting the process in order to change the controller settings to compartible IDE mode (only if available in the system BIOS/UEFI). OK press 1 or ENTER or END or ESC, if i use HDD Regenerator 2024 v20.24.0.0 downloaded from: https://es.taiwebs.com/windows/download-hdd-regenerator-9948.html, to repair under Windows my HDD Storage Device, in an intel core i7 8700 processor, ROG Maximus XI Gene EVGA 750BQ Power Supply a Intel Optane Memory a NVIDIA Geforce GTX 1650 Super GPU and a GeIL CL16-16-16 D4-2400 8 GB RAM memory
Devi_Intel
Hi cmimf
Greetings
Thank you for posting memory & storage. I'm here to follow up case as per subject. Appreciate  if you can provide us with the following information:
1.Go to https://downloadcenter.intel.com/download/25293/ and download the software.
2.When finished downloading it, open it.
3.Attach the file obtained to your reply.
We will be looking forward to your reply including this information.
Thank you & Best regards,
Devi_Intel
Devi_Intel
Greeting cmimf,
Regarding your case number 06025537, we are following up to find out if you were able to complete the actions we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply
Thank you & Best Regards,
Devi_Intel
Devi_Intel
Hello cmimf
Your issue is now considered resolved, therefore we are proceeding to close this ticket.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Devi_Intel
