IntelĀ® Optaneā„¢ Memory
Support for Issues Related to IntelĀ® Optaneā„¢ Memory
Want to learn how IntelĀ® Optaneā„¢ Memory can help your business? Talk to our Expert!
The IntelĀ® SSD Toolbox and IntelĀ® Data Center Tool are now End-Of-Life, see for more information and replacements tools here
why my pc don't see optane?
rcent3
Hi, i have Intel optane 16gb , i have a gigabyte z370-HD3P .
I more tried a reboot the pc, and change setting in bios , but my pc don't see optane.. why? is it broken?
sorry for my bad english
n_scott_pearson
Is the Optane module enabled? If it is enabled, it will not be seen as being a separate device; it will be seen as being part of the drive that it is accelerating.
n_scott_pearson
Also, if you are more comfortable this way, feel free to post in your native language. We can use translators to read your posts.
If you do this, however, remember that we cannot translate text that is in a picture or screen capture. You need to include the text itself in your post so that we can translate it.
rcent3
ciao e grazie per le risposte.
Come si abilita il modulo optane? io ho utilizzato la guida che si trovava libretto di istruzioni della mia scheda madre, ma senza risultati . Ho provato a cambiare anche il software di intel , il primo software "intel rapid storage" optane non veniva rilevato, il secondo software "memoria intel optane" mi da un errore "nessun disco compatibile per la memoria intel optane". allego tutto con foto
rcent3
non mi fa aggiungere più di una foto per messaggio
LeonWaksman
Hello @rcent3​
Pleas attach an image of Disk Management.
Leon
rcent3
fatto 😊
LeonWaksman
  1. Your Optane memory is not recognized in BIOS.
  2. Try to install Optane memory in the second M.2 slot. Try to reset it again in the M.2 slot.
  3. You may also ask Gigabyte support for help.
Leon
