Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
Annonces
484 Discussions
Intel SSD 730 PCIe and SSD Toolbox Optimizer
Employé
2 175 Visites
I have 1.2TB Intel SSD 730 (slot PCIe) ad my primary disk (Windows 10). I installed Intel SSD toolbox, but the Optimizer function is greyed out.
I think that the problem is with my NVMe driver (that I find ad Microsoft and not Intel...)
Any suggestion?
0 Compliments
3 Réponses
Employé
1 314 Visites
Hello Calefal,
In order to better assist you, we would like to have some additional information:
1. We don't have a 1.2TB NVMe* version of the http://ark.intel.com/products/series/81040/Consumer-SSDs Intel® SSD 730 Series. Are you referring to the http://ark.intel.com/products/86739/Intel-SSD-750-Series-1_2TB-12-Height-PCIe-3_0-20nm-MLC Intel® SSD 750 Series?
2. Please open Command Prompt as Administrator, then run the following command to know if TRIM is enabled in the OS:
fsutil behavior query disabledeletenotify
If DisableDeleteNotify = 1 (Windows TRIM commands are disabled)
If DisableDeleteNotify = 0 (Windows TRIM commands are enabled)
3. Make sure you're using our https://downloadcenter.intel.com/download/26167/Intel-SSD-Data-Center-Family-for-NVMe-Drivers latest driver for NVMe* SSDs. (http://www.intel.com/content/dam/support/us/en/documents/ssdc/data-center-ssds/Intel%20NVMe%20Install%20Guide_330547-003.pdf Installation Guide - Page 8)
4. Make sure you're using the latest version of the https://downloadcenter.intel.com/download/26306/Intel-Solid-State-Drive-Toolbox Intel® Solid State Drive Toolbox
5. If possible provide a screen capture (snip) of the toolbox showing the problem.
We look forward to hearing back from you.
Carlos A.
0 Compliments
Employé
1 314 Visites
Sorry my fault... Intel 750 (not 730)... I've found this file: Intel® SSD Data Center Family for NVMe Drivers (NVMe driver 1.7.0.1002) and now toolbox optimizer is working
TRIM is enabled
I also installed "Intel® SSD Data Center Family for NVMe Drivers" from your link, but actually I'm not able to use it (I suppose I should learn its sintax)
0 Compliments
Employé
1 314 Visites
Hello Calefal,
We're glad to hear your issue was resolved.
If you need further assistance please let us know
Carlos A.
0 Compliments
Répondre
