17259 Discussions
10500 VHDL syntax error on my counter design.
I was wondering if anyone could help me out with solving this error messages.
1 : 10500 VHDL syntax error at coin_reference.vhd(210) near text "then"; expecting ")", or ","
2: 10500 VHDL syntax error at coin_reference.vhd(216) near text "if"; expecting "process".
my counter design is
(line 207) process(G_DOUT(0))
variable count0 : integer range 0 to 65535;
begin
if(rising_edge(G_DOUT(0)) then
if RESET_CLOCK(0) = '1' then
count0 := 0;
elsif enable='1' then
count0 := count0 + 1;
end if;
end if;
Q0 <= count0;
end process;
I honestly don't see what is wrong with it.
you're missing a ')' in line 210.
oh wow, should have spotted that. Thank alot!
While we're here though, Im a bit concerned you're using a data output as a clock . You should not use logic as clocks. You should only ever use clocks and use the logic as a clock enable.
Yea I've had to change that, the information is only passed to G_DOUT(0) at the very end now, when there is nothing else to perform.
