17254 Discussions
20ns pulse generation at rising edge
I'd like to generate a 20ns high signal at the rising edge of another (clocked, 330ns) signal.
Formally, they are a 50MHz clock and a 3MHz clock.
Right now, I am stuck at the very beginnin' of this task. I mean, I found many codes that can generate a pulse if a rising edge condition is meet. Anyway, there's no control on the pulse duration.
I was thinking of a signal locked at the rising edge of the 3Mhz signal to trigger a state machine clocked @50Mhz. My problem is that I can't figure out how to deassert the trigger signal, since it will deassert on the next rising edge of the control signal.
Here is a (wrong) code I made since now - i didn't include resets here to make it easibily readable.
I don't expect a solution, or it to work. I'd like just a hint.
--- Quote Start ---
always@(posedge 3Mhz_signa)
begin
up<=1;
end
always@(posedge 50Mhz_signal) begin
case(fsm)
0:begin;
data_out<=0;
if up(fsm<=1);
end
1:begin;
data_out<=1;
fsm<=0;
end
endcase
endmodule
--- Quote End ---
how can i deassert "up" signal after 20ns, being locked to posedge 3Mhz clk?
I was thinking of a sort of "feedback", but still not ideas.
EDIT:
i seems like I didn't search enough on google.
I found out this (http://www.oldcrows.net/~patchell/iparchive/oneshot.v) that's exactly what I needed.
Basically, feedback was the right way.
I've a long way to proper learn coding.
So you need your trigger to be aligned with the rising edge of the 3 MHz clock and then go low 20 ns later? Did I understand you correctly? This is not possible with the clocks that you have.
However, you can make a 20 ns pulse when a rising edge on 3 MHz is detected using the 50 MHz clock. The issue with what you are trying to do is that the 3 MHz and the 50 MHz clocks are not synchronous.
/Boris
I wanted a pulse generation triggered by the rising edge of the 3MHz Clok - I understand your point now, you're right.
Anyway, the link I posted seems to be fair enough for my purpose, right now. I'll be back on the pulse generation, maybe.
