4bit siso shift register
I used the following code for 4bit siso shift register.
Signal temp : std_logic_vector( 3downtown 0);
begin
process
begin
if(rising_edge(clk)) then
temp(3 downtown 1)<=temp(2 downto 0);
temp(0)<=si;
end if;
end process;
so<=temp(3);
end behavioural;
I used the following testbench code.
clk<= '0';
si<='1';
wait for 100ns;
clk<= '1';
si<='1';
wait for 100ns;
But after stimulation its shows that so is undefined i.e
a red bar is shown....
Pls help......
You only show a single clock in the testbench code. It will take 4 clocks for si to propogate to so.
clk<= '0';
si<='1';
wait for 100ns;
clk<= '1';
si<='1';
wait for 100ns;
clk<= '0';
si<='1';
wait for 100ns;
clk<= '1';
si<='1';
wait for 100ns;
clk<= '0';
si<='1';
wait for 100ns;
clk<= '1';
si<='1';
wait for 100ns;
clk<= '0';
si<='1';
wait for 100ns;
clk<= '1';
si<='1';
wait for 100ns;
I have used the above coding.....
Even if I use 4 clocks its still shows the red bar
Pls help.....
Please post all of your code, not just an extract.
did you try to initialize temp(3 downto 0) to an initial value? If not you need at least 4 clock edges to get "so" "green"
if "red" it would be that you never put anything on it...
AND , you have to put "clock" in the process sensitivity list....
