17263 Discussions
7 segment display from 4 bit binary
So I understand what this is supposed to be doing in theory. However in practice I can't find any practical examples. Basically I have a circuit with two 4 bit numbers in, with a switch (S) to select between the two, and the selected number is shown on the 7 segment display.
Could someone please tell me what I need to change for the syntax of this to compile?
Or alternatively if there is an easier way, I would happily use that. From all the examples I could find this seemed like the best way. currently when trying to compile this error displays for each line of the case statement
Error (10500): VHDL syntax error at test2.vhd(37) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
ENTITY test2 IS PORT( AI :IN STD_LOGIC_VECTOR(3 DOWNTO 0); BI :IN STD_LOGIC_VECTOR(3 DOWNTO 0); S :IN BIT; S7 :OUT STD_LOGIC_VECTOR(6 DOWNTO 0)); END test2; ARCHITECTURE behavior OF test2 IS PROCESS (AI, BI) BEGIN IF (S=0) CASE "AI" is when "0000"=> S7 <="0000001"; --1 when "0001"=> S7 <="1001111"; --2 (etc) when "0010"=> S7 <="0010010"; when "0011"=> S7 <="0000110"; when "0100"=> S7 <="1001100"; when "0101"=> S7 <="0100100"; when "0110"=> S7 <="0100000"; when "0111"=> S7 <="0001111"; when "1000"=> S7 <="0000000"; when "1001"=> S7 <="0000100"; when others => S7 <="1001111"; -- e for error END CASE; END IF; IF (S=1) CASE "AI" is when "0000"=> S7 <="0000001"; when "0001"=> S7 <="1001111"; when "0010"=> S7 <="0010010"; when "0011"=> S7 <="0000110"; when "0100"=> S7 <="1001100"; when "0101"=> S7 <="0100100"; when "0110"=> S7 <="0100000"; when "0111"=> S7 <="0001111"; when "1000"=> S7 <="0000000"; when "1001"=> S7 <="0000100"; when others => S7 <="1001111"; -- e for error END CASE; END IF; END PROCESS; END behavior;
Thank you so much for your time
AI should not be in ""
Theres a couple of other bugs:
1. 2nd case statement should use BI
2. You havent put S in the process sensitivity list.
So having fixed those, I'm still left with the same amount of errors. I know its something silly with syntax. Here it is having fixed those things
ENTITY test2 IS PORT( AI :IN STD_LOGIC_VECTOR(3 DOWNTO 0); BI :IN STD_LOGIC_VECTOR(3 DOWNTO 0); S :IN BIT; S7 :OUT STD_LOGIC_VECTOR(6 DOWNTO 0)); END test2; ARCHITECTURE behavior OF test2 IS PROCESS (AI, BI, S) BEGIN IF (S=0) CASE AI is when "0000"=> S7 <="0000001"; when "0001"=> S7 <="1001111"; when "0010"=> S7 <="0010010"; when "0011"=> S7 <="0000110"; when "0100"=> S7 <="1001100"; when "0101"=> S7 <="0100100"; when "0110"=> S7 <="0100000"; when "0111"=> S7 <="0001111"; when "1000"=> S7 <="0000000"; when "1001"=> S7 <="0000100"; when others => S7 <="1001111"; -- e for error END CASE; END IF; IF (S=1) CASE BI is when "0000"=> S7 <="0000001"; when "0001"=> S7 <="1001111"; when "0010"=> S7 <="0010010"; when "0011"=> S7 <="0000110"; when "0100"=> S7 <="1001100"; when "0101"=> S7 <="0100100"; when "0110"=> S7 <="0100000"; when "0111"=> S7 <="0001111"; when "1000"=> S7 <="0000000"; when "1001"=> S7 <="0000100"; when others => S7 <="1001111"; -- e for error END CASE; END IF; END PROCESS; END behavior;
Keeps telling me every line is expecting a (, end, or an identifier.
try:
if s = '0' then
if s = '1' then
Still results in 15 errors. Here's the full error paste up
Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 9.1 Build 350 03/24/2010 Service Pack 2 SJ Web Edition Info: Processing started: Sun Nov 09 12:46:10 2014 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off test2 -c test2 Error (10500): VHDL syntax error at test2.vhd(10) near text "PROCESS"; expecting "begin", or a declaration statement Error (10500): VHDL syntax error at test2.vhd(16) near text "=>"; expecting ";" Error (10500): VHDL syntax error at test2.vhd(33) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(34) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(35) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(36) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(37) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(38) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(39) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(40) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(41) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(43) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at test2.vhd(44) near text "CASE"; expecting ";", or an identifier ("case" is a reserved keyword), or "architecture" Info: Found 0 design units, including 0 entities, in source file test2.vhd Error: Quartus II Analysis & Synthesis was unsuccessful. 13 errors, 0 warnings Error: Peak virtual memory: 231 megabytes Error: Processing ended: Sun Nov 09 12:46:13 2014 Error: Elapsed time: 00:00:03 Error: Total CPU time (on all processors): 00:00:03 Error: Quartus II Full Compilation was unsuccessful. 15 errors, 0 warnings
You forgot the begin for the architecture.
Its important when learning VHDL to learn how to use both Quartus for synthesis and Modelsim for simulation. I posted an example a while back ...
http://www.alteraforum.com/forum/showthread.php?t=45770
No looking at this thread until your code compiles :)
Cheers,
Dave
