7 segment display
Hi all.
I have problem to display "HELLO" on 7 segment display. Even though my vhdl code is successful, but its only display "H" on HEX0. Here is my code. I want to display "HELLO" on 7 segment. "H" on HEX0, "E" on HEX1, "L" on HEX2, "L" on HEX3, "O" on HEX4. Do you have any ideas regarding my problem. Thanks in advance
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY part5 IS
PORT ( SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0);
HEX0,HEX1,HEX2,HEX3,HEX4 : OUT STD_LOGIC_VECTOR(0 TO 6));
END part5;
ARCHITECTURE Behavior OF part5 IS
COMPONENT mux_3bit_5to1
PORT ( S, U, V, W, X, Y : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
M : OUT STD_LOGIC_VECTOR(2 DOWNTO 0));
END COMPONENT;
COMPONENT char_7seg
PORT ( C : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
Display : OUT STD_LOGIC_VECTOR(0 TO 6));
END COMPONENT;
SIGNAL M : STD_LOGIC_VECTOR(2 DOWNTO 0);
BEGIN
M0: mux_3bit_5to1 PORT MAP (SW(17 DOWNTO 15), SW(14 DOWNTO 12), SW(11 DOWNTO 9), SW(8 DOWNTO 6), SW(5 DOWNTO 3), SW(2 DOWNTO 0), M);
H0: char_7seg PORT MAP (M,HEX0);
END Behavior;
LIBRARY ieee;
use ieee.std_logic_1164.all;
ENTITY mux_3bit_5to1 IS
END mux_3bit_5to1;
ARCHITECTURE Behavior OF mux_3bit_5to1 IS
begin
Behavior: with S select
M <= U when "000",
V when "001",
W when "010",
X when "011",
Y when "100",
Y when "101",
Y when "110",
Y when "111";
END Behavior;
LIBRARY ieee;
ENTITY char_7seg IS
END char_7seg;
ARCHITECTURE Behavior OF char_7seg IS
signal input : std_logic_vector (2 downto 0);--define input bit
signal output : std_logic_vector ( 6 downto 0);--define output bit
begin
input <= C;
with input select
Display <= "1001000" when "000" ,
"0110000" when "001",
"1110001" when "010",
"0000001" when "011",
"1111111" when others;
end Behavior;
You have 4 output vectors so:
HEX0 <= "0110000";
HEX1 <= "1110001";
HEX2 <= "0000001";
HEX3 <= "1111111";
The behaviour you observe is correct, since you are NOT driving HEX1 to HEX4 lines, but only HEX0.
Although I don't know if this is really what you mean to do, I suggest you replace the line
with:
char_7seg PORT MAP (SW(14 DOWNTO 12),HEX0);
char_7seg PORT MAP (SW(11 DOWNTO 9),HEX0);
char_7seg PORT MAP (SW(8 DOWNTO 6),HEX0);
char_7seg PORT MAP (SW(5 DOWNTO 3),HEX0);
char_7seg PORT MAP (SW(2 DOWNTO 0),HEX0);
Thanks bertulus and Cris72 for your suggestion. Have solve it.
