Hi all.
I have problem to display "HELLO" on 7 segment display. Even though my vhdl code is successful, but its only display "H" on HEX0. Here is my code. I want to display "HELLO" on 7 segment. "H" on HEX0, "E" on HEX1, "L" on HEX2, "L" on HEX3, "O" on HEX4. Do you have any ideas regarding my problem. Thanks in advance LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY part5 IS PORT ( SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0); HEX0,HEX1,HEX2,HEX3,HEX4 : OUT STD_LOGIC_VECTOR(0 TO 6)); END part5; ARCHITECTURE Behavior OF part5 IS COMPONENT mux_3bit_5to1 PORT ( S, U, V, W, X, Y : IN STD_LOGIC_VECTOR(2 DOWNTO 0); M : OUT STD_LOGIC_VECTOR(2 DOWNTO 0)); END COMPONENT; COMPONENT char_7seg PORT ( C : IN STD_LOGIC_VECTOR(2 DOWNTO 0); Display : OUT STD_LOGIC_VECTOR(0 TO 6)); END COMPONENT; SIGNAL M : STD_LOGIC_VECTOR(2 DOWNTO 0); BEGIN M0: mux_3bit_5to1 PORT MAP (SW(17 DOWNTO 15), SW(14 DOWNTO 12), SW(11 DOWNTO 9), SW(8 DOWNTO 6), SW(5 DOWNTO 3), SW(2 DOWNTO 0), M); H0: char_7seg PORT MAP (M,HEX0); END Behavior; LIBRARY ieee; use ieee.std_logic_1164.all; ENTITY mux_3bit_5to1 IS PORT ( S, U, V, W, X, Y : IN STD_LOGIC_VECTOR(2 DOWNTO 0); M : OUT STD_LOGIC_VECTOR(2 DOWNTO 0)); END mux_3bit_5to1; ARCHITECTURE Behavior OF mux_3bit_5to1 IS begin Behavior: with S select M <= U when "000", V when "001", W when "010", X when "011", Y when "100", Y when "101", Y when "110", Y when "111"; END Behavior; LIBRARY ieee; use ieee.std_logic_1164.all; ENTITY char_7seg IS PORT ( C : IN STD_LOGIC_VECTOR(2 DOWNTO 0); Display : OUT STD_LOGIC_VECTOR(0 TO 6)); END char_7seg; ARCHITECTURE Behavior OF char_7seg IS signal input : std_logic_vector (2 downto 0);--define input bit signal output : std_logic_vector ( 6 downto 0);--define output bit begin input <= C; with input select Display <= "1001000" when "000" , "0110000" when "001", "1110001" when "010", "0000001" when "011", "1111111" when others; end Behavior;Link Copied
You have 4 output vectors so:
HEX0 <= "0110000"; HEX1 <= "1110001"; HEX2 <= "0000001"; HEX3 <= "1111111";- Mark as New
The behaviour you observe is correct, since you are NOT driving HEX1 to HEX4 lines, but only HEX0.
Although I don't know if this is really what you mean to do, I suggest you replace the line H0: char_7seg PORT MAP (M,HEX0); with: char_7seg PORT MAP (SW(14 DOWNTO 12),HEX0); char_7seg PORT MAP (SW(11 DOWNTO 9),HEX0); char_7seg PORT MAP (SW(8 DOWNTO 6),HEX0); char_7seg PORT MAP (SW(5 DOWNTO 3),HEX0); char_7seg PORT MAP (SW(2 DOWNTO 0),HEX0);- Mark as New
Thanks bertulus and Cris72 for your suggestion. Have solve it.
