- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi, im trying to make a 8bits to 3digits 7segments decoder usind a double dabble, but there is something wrong with my code and i dont know what, can you help me?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
package my_pkg is
function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector;
end package my_pkg;
package body my_pkg is
function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector is
variable i : integer:=0;
variable bcd : std_logic_vector(11 downto 0) := (others => '0');
variable bint : std_logic_vector(7 downto 0) := bin;
begin
for i in 0 to 7 loop
bcd(11 downto 1) := bcd(10 downto 0);
bcd(0) := bint(7);
bint(7 downto 1) := bint(6 downto 0);
bint(0) :='0';
if(i < 7 and bcd(3 downto 0) > "0100") then
bcd(3 downto 0) := bcd(3 downto 0) + "0011";
end if;
if(i < 7 and bcd(7 downto 4) > "0100") then
bcd(7 downto 4) := bcd(7 downto 4) + "0011";
end if;
if(i < 7 and bcd(11 downto 8) > "0100") then
bcd(11 downto 8) := bcd(11 downto 8) + "0011";
end if;
end loop;
return bcd;
end to_bcd;
end package body my_pkg;
entity termometro is
port (
clk: in std_logic;
data: in std_logic_vector(7 downto 0);
Di: out std_logic_vector (6 downto 0);
Vtc:out std_logic_vector(3 downto 0));
end termometro;
architecture behavior of termometro is
signal bcd1, bcd2, bcd3: std_logic_vector(3 downto 0);
type segs is(se0, se1, se2);
signal seg_atual, prox_seg: segs;
signal S1, S2, S3: std_logic_vector(6 downto 0);
begin
bcd1<=to_bcd(3 downto 0);
bcd2<=to_bcd(7 downto 4);
bcd3<=to_bcd(11 downto 7);
process(bcd1, bcd2, bcd3)
begin
WITH bcd1 SELECT
S1 <= "1111110" when "0000",
"0110000" when "0001",
"1101101" when "0010",
"1111001" when "0011",
"0110011" when "0100",
"1011011" when "0101",
"0100000" when "0110",
"1110000" when "0111",
"1111111" when "1000",
"1111011" when "1001",
"0000000" when others;
WITH bcd2 SELECT
WITH bcd3 SELECT
end process;
process(clk) is
begin
if(clk = '1' and clk'event) then
seg_atual<=prox_seg;
end if;
end process;
process (S1, S2, S3) is
begin
case seg_atual is
when se0=>
Di <= S1;
Vtc<= "0001";
prox_seg <= se1;
when se1 =>
Di <= S2;
Vtc<= "0010";
prox_seg <= se2;
when se2 =>
Di <= S3";
Vtc<= "0100";
prox_seg <= se3;
end case;
end process;
end behavior;
링크가 복사됨
7 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- What is the 'something' that is wrong with your code? --- Quote End --- it says that is something wrong with de syntax but there isnt, so i coment this part and then other error apears but none of them are usefull the compiler doesn't seems to know what's wrong with the code, the syntax itself is correct, i triplecheck it the thing is, i dont know what is this something, thats why im asking for help xD
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Well my suggestion is to read the error message and to fix whatever it is saying is wrong with your code.
Without the error messages themselves it is difficult to give more help. There is at least an error that I can see in your code. You used a with...select construction, that is a concurrent statement and can't be placed in a process. Either put it outside or use a case statement.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Between the 'end package body my_pkg;' and the following entity you have to (re-)declare all used libraries (including the above defined package)
Your FSM is not fully elaborated (missing state se3.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Did both things but still not working
library ieee;
package my_pkg is
end package my_pkg;
library ieee;
begin
bcd(0) := bint(7);
bint(0) :='0';
end if;
end if;
end if;
end loop;
return bcd;
end to_bcd;
port (
clk: in std_logic;
end termometro;
begin
WITH bcd1 SELECT
WITH bcd2 SELECT
WITH bcd3 SELECT
process(clk) is
begin
end if;
end process;
begin
case seg_atual is
when se0=>
Di <= S1;
Vtc<= "0001";
prox_seg <= se1;
when se1 =>
Di <= S2;
Vtc<= "0010";
prox_seg <= se2;
when se2 =>
Di <= S3";
Vtc<= "0100";
prox_seg <= se3;
end case;
end process;
end behavior;
the following error occured: Error (10500): VHDL syntax error at termometro.vhd(126) near text "";" end of line inside a string Error (10500): VHDL syntax error at termometro.vhd(126) near text "";"; expecting ";" same as before tried change the syntax but still nothing
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Take some time, look at the error. It is on line 126. Look closely, your compiler is trying to help you. See lines 118 and 122 for reference.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Take some time, look at the error. It is on line 126. Look closely, your compiler is trying to help you. See lines 118 and 122 for reference. --- Quote End --- i wasn't the main problem, but i already solved it
library ieee;
use ieee.std_logic_unsigned.all;
package my_pkg is
end package my_pkg;
variable aux: std_logic_vector (20 downto 0);
variable bcd: std_logic_vector(11 downto 0);
begin
aux := (OTHERS=>'0');
aux(8 downto 1) := bin(7 downto 0);
if aux(12 downto 9) > 4 then
aux(12 downto 9) := aux(12 downto 9) + 3;
end if;
if aux(16 downto 13) > 4 then
aux(16 downto 13) := aux(16 downto 13) + 3;
end if;
aux(20 downto 1) := aux(19 downto 0);
end loop;
bcd := aux(20 downto 9);
return bcd;
end to_bcd;
library ieee;
library work;
use work.my_pkg.all;
port (
Vtc:out std_logic_vector(2 downto 0); -- como soh usarar 3 displays nao precisa colocar energia nos 4
clk: in std_logic
end termometro;
signal aux: std_logic_vector(11 downto 0);
begin
aux <= to_bcd(data);
bcd1<=aux(3 downto 0);
bcd2<=aux(7 downto 4);
bcd3<=aux(11 downto 8);
WITH bcd1 SELECT
WITH bcd2 SELECT
S2 <= "1111110" when "0000",
WITH bcd3 SELECT
S3 <= "1111110" when "0000",
process(clk) is
begin
end if;
end process;
begin
case seg_atual is
when se0=>
Di <= S1;
Vtc<= "001";
prox_seg <= se1;
when se1 =>
Di <= S2;
Vtc<= "010";
prox_seg <= se2;
when se2 =>
Di <= S3;
Vtc<= "100";
prox_seg <= se0;
end case;
end process;
end behavior;
