17246 Discussions
8bits to 7segments decoder
Hi, im trying to make a 8bits to 3digits 7segments decoder usind a double dabble, but there is something wrong with my code and i dont know what, can you help me?
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; package my_pkg is function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector; end package my_pkg; package body my_pkg is function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector is variable i : integer:=0; variable bcd : std_logic_vector(11 downto 0) := (others => '0'); variable bint : std_logic_vector(7 downto 0) := bin; begin for i in 0 to 7 loop bcd(11 downto 1) := bcd(10 downto 0); bcd(0) := bint(7); bint(7 downto 1) := bint(6 downto 0); bint(0) :='0'; if(i < 7 and bcd(3 downto 0) > "0100") then bcd(3 downto 0) := bcd(3 downto 0) + "0011"; end if; if(i < 7 and bcd(7 downto 4) > "0100") then bcd(7 downto 4) := bcd(7 downto 4) + "0011"; end if; if(i < 7 and bcd(11 downto 8) > "0100") then bcd(11 downto 8) := bcd(11 downto 8) + "0011"; end if; end loop; return bcd; end to_bcd; end package body my_pkg; entity termometro is port ( clk: in std_logic; data: in std_logic_vector(7 downto 0); Di: out std_logic_vector (6 downto 0); Vtc:out std_logic_vector(3 downto 0)); end termometro; architecture behavior of termometro is signal bcd1, bcd2, bcd3: std_logic_vector(3 downto 0); type segs is(se0, se1, se2); signal seg_atual, prox_seg: segs; signal S1, S2, S3: std_logic_vector(6 downto 0); begin bcd1<=to_bcd(3 downto 0); bcd2<=to_bcd(7 downto 4); bcd3<=to_bcd(11 downto 7); process(bcd1, bcd2, bcd3) begin WITH bcd1 SELECT S1 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; WITH bcd2 SELECT S1 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; WITH bcd3 SELECT S1 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; end process; process(clk) is begin if(clk = '1' and clk'event) then seg_atual<=prox_seg; end if; end process; process (S1, S2, S3) is begin case seg_atual is when se0=> Di <= S1; Vtc<= "0001"; prox_seg <= se1; when se1 => Di <= S2; Vtc<= "0010"; prox_seg <= se2; when se2 => Di <= S3"; Vtc<= "0100"; prox_seg <= se3; end case; end process; end behavior;
What is the 'something' that is wrong with your code?
--- Quote Start ---
--- Quote End ---
it says that is something wrong with de syntax but there isnt, so i coment this part and then other error apears but none of them are usefull
the compiler doesn't seems to know what's wrong with the code, the syntax itself is correct, i triplecheck it
the thing is, i dont know what is this something, thats why im asking for help xD
Well my suggestion is to read the error message and to fix whatever it is saying is wrong with your code.
Without the error messages themselves it is difficult to give more help.
There is at least an error that I can see in your code. You used a with...select construction, that is a concurrent statement and can't be placed in a process. Either put it outside or use a case statement.
Between the 'end package body my_pkg;' and the following entity you have to (re-)declare all used libraries (including the above defined package)
Your FSM is not fully elaborated (missing state se3.
Did both things but still not working
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; package my_pkg is function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector; end package my_pkg; library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; package body my_pkg is function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector is variable i : integer:=0; variable bcd : std_logic_vector(11 downto 0) := (others => '0'); variable bint : std_logic_vector(7 downto 0) := bin; begin for i in 0 to 7 loop bcd(11 downto 1) := bcd(10 downto 0); bcd(0) := bint(7); bint(7 downto 1) := bint(6 downto 0); bint(0) :='0'; if(i < 7 and bcd(3 downto 0) > "0100") then bcd(3 downto 0) := bcd(3 downto 0) + "0011"; end if; if(i < 7 and bcd(7 downto 4) > "0100") then bcd(7 downto 4) := bcd(7 downto 4) + "0011"; end if; if(i < 7 and bcd(11 downto 8) > "0100") then bcd(11 downto 8) := bcd(11 downto 8) + "0011"; end if; end loop; return bcd; end to_bcd; end package body my_pkg; entity termometro is port ( clk: in std_logic; data: in std_logic_vector(7 downto 0); Di: out std_logic_vector (6 downto 0); Vtc:out std_logic_vector(3 downto 0)); end termometro; architecture behavior of termometro is signal bcd1, bcd2, bcd3: std_logic_vector(3 downto 0); type segs is(se0, se1, se2); signal seg_atual, prox_seg: segs; signal S1, S2, S3: std_logic_vector(6 downto 0); begin bcd1<=to_bcd(3 downto 0); bcd2<=to_bcd(7 downto 4); bcd3<=to_bcd(11 downto 7); WITH bcd1 SELECT S1 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; WITH bcd2 SELECT S1 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; WITH bcd3 SELECT S1 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; process(clk) is begin if(clk = '1' and clk'event) then seg_atual<=prox_seg; end if; end process; process (S1, S2, S3) is begin case seg_atual is when se0=> Di <= S1; Vtc<= "0001"; prox_seg <= se1; when se1 => Di <= S2; Vtc<= "0010"; prox_seg <= se2; when se2 => Di <= S3"; Vtc<= "0100"; prox_seg <= se3; end case; end process; end behavior;
the following error occured:
Error (10500): VHDL syntax error at termometro.vhd(126) near text "";" end of line inside a string
Error (10500): VHDL syntax error at termometro.vhd(126) near text "";"; expecting ";"
same as before
tried change the syntax but still nothing
Take some time, look at the error. It is on line 126. Look closely, your compiler is trying to help you. See lines 118 and 122 for reference.
--- Quote Start ---
--- Quote End ---
i wasn't the main problem, but i already solved it
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; package my_pkg is function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector; end package my_pkg; package body my_pkg is function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector is variable aux: std_logic_vector (20 downto 0); variable bcd: std_logic_vector(11 downto 0); begin aux := (OTHERS=>'0'); aux(8 downto 1) := bin(7 downto 0); for i in 0 to 7 loop if aux(12 downto 9) > 4 then aux(12 downto 9) := aux(12 downto 9) + 3; end if; if aux(16 downto 13) > 4 then aux(16 downto 13) := aux(16 downto 13) + 3; end if; aux(20 downto 1) := aux(19 downto 0); end loop; bcd := aux(20 downto 9); return bcd; end to_bcd; end package body my_pkg; library ieee; use ieee.std_logic_1164.all; library work; use work.my_pkg.all; entity termometro is port ( data: in std_logic_vector(7 downto 0); Di: out std_logic_vector (6 downto 0); Vtc:out std_logic_vector(2 downto 0); -- como soh usarar 3 displays nao precisa colocar energia nos 4 clk: in std_logic ); end termometro; architecture behavior of termometro is signal bcd1, bcd2, bcd3: std_logic_vector(3 downto 0); signal aux: std_logic_vector(11 downto 0); type segs is(se0, se1, se2); signal seg_atual, prox_seg: segs; signal S1, S2, S3: std_logic_vector(6 downto 0); begin aux <= to_bcd(data); bcd1<=aux(3 downto 0); bcd2<=aux(7 downto 4); bcd3<=aux(11 downto 8); WITH bcd1 SELECT S1 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; WITH bcd2 SELECT S2 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; WITH bcd3 SELECT S3 <= "1111110" when "0000", "0110000" when "0001", "1101101" when "0010", "1111001" when "0011", "0110011" when "0100", "1011011" when "0101", "0100000" when "0110", "1110000" when "0111", "1111111" when "1000", "1111011" when "1001", "0000000" when others; process(clk) is begin if(clk = '1' and clk'event) then seg_atual<=prox_seg; end if; end process; process (S1, S2, S3) is begin case seg_atual is when se0=> Di <= S1; Vtc<= "001"; prox_seg <= se1; when se1 => Di <= S2; Vtc<= "010"; prox_seg <= se2; when se2 => Di <= S3; Vtc<= "100"; prox_seg <= se0; end case; end process; end behavior;
