17267 Discussions
A question about vector port declaration
I have a question about port declaration which confuses me:
In VHDL, for ports or signals, we can define as:
A : out std_logic_vector(0 to 15);
signal B,C : std_logic_vector(7 downto 0);
I personally prefer the 2nd one but sometimes IP or modules from other engineers may be defined in 1st style. Now I have a question:
if I do:
A<=B & C;
Does this operation do is:
A(15 downto 8)<= B;
A(7 downto 0) <= C;
Or is:
A(15 donwto 8) <= C;
A(7 downto 0) <= B;
or neither of them?
Thanks in advance.
To make it easy to understand and be absolutely sure, I would say: why won't you just write it down the way you want it to be. So if you want to do
A(15 downto 8)<= B;
A(7 downto 0) <= C;
That's what you write down, if you want it the other way, you write it the other way.
But for the statement itself I would assume it means the first one, but I'm not sure.
To be sure you could always try to put some known values in it and see what happens
*edit*
Oops sorry misread the question, ignore this message, I'm sorry for the inconvenience
--- Quote Start ---
if I do:
A<=B & C;
A(15 downto 8)<= B;
A(7 downto 0) <= C;
Or is:
A(7 downto 0) <= B;
or neither of them?
Thanks in advance.
--- Quote End ---
neither.
As far as I know the location of bit (not the index) defines its weight in the bus.
thus
A <= B&C; means A(0 to 7) <= B, A(8 to 15) <= B
but the compiler may not accept this assignment.
so it is always better to use 15 downto 0 to avoid bit index confusion
Thanks, Kaz. But for:
A(0 to 7)<=B;
Is A(0) <= B(7), or it is still A(0) <= B(0) ? It is very confusing. Some IP ports design is very annoying!
--- Quote Start ---
--- Quote End ---
It's A(0) <= B(7), as kaz said, it's copied according to the position, leftmost to leftmost, etc.
If you want to copy B(0) to A(0), you'll use a for loop.
Thanks very much, FvM. I got it.
