17258 Discussions
A synchronous clear enable conter RTL
I have issues with RTL of simple counter: a synchronous clear enable counter.
I use Altera template to be confident as much as possible.
http://quartushelp.altera.com/14.1/mergedprojects/hdl/vlog/vlog_pro_counters.htm
https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-handbook.pdf HDL guides for counters on 12-57
I expect such counter to consist of one adder, one mux and one register, but I get two muxes if using provided template. Instead of using EN input of register second mux is implemented. How do I specify to use EN input of register?
Can someone provide information on this issue? Maybe I don't understand something.
I've tried to change synthesis options and it did't work.
I can implement my vision of RLT with one MUX using d = a?b:c operand. But I find it kind of akward.
See code below.
module counter ( input en, clk, rst, output reg count, output reg count2); // One MUX RTL wire new_count = rst ? 4'd0 : count + 1; always @(posedge clk) begin if (en) count <= new_count; end // Two MUX RTL (using altera template) always @(posedge clk) begin if (rst) count2 <= 0; else if (en) count2 <= count2 + 1; end endmodule
