17261 Discussions
PRE_FLOW_SCRIPT_FILE problem
Hi.
I am trying to write the script for automatic update compilation time in my project. The script generate_version1.tcl:
set str -format {%Y%m%d%H%M}] set hex_value ${str} set num_digits set bit_width set high_index set reset_value set fh puts $fh "module version_reg (clock, reset, data_out);" puts $fh " input clock;" puts $fh " input reset;" puts $fh " output \ data_out;" puts $fh " reg \ data_out;" puts $fh " always @ (posedge clock or negedge reset) begin" puts $fh " if (!reset)" puts $fh " data_out <= ${bit_width}'h${reset_value};" puts $fh " else" puts $fh " data_out <= ${bit_width}'h${hex_value};" puts $fh " end" puts $fh "endmodule" close $fh
This script generate version_reg.v file which contain the time. version_reg.v file included in my project.
I run:Tools->Tck Scripts...->generate_version1.tcl and this method work correct. I try to launch this cript automaticaly by adding in my qsf file: set_global_assignment -name PRE_FLOW_SCRIPT_FILE "quartus_sh:generate_version1.tcl" But then I launch compilation, the script does not execute.
Operation system : Windows7
Quartus:13.0.1
PATH: C:\altera\13.0sp1\quartus\bin64
Also I try to use Tcl Console: "quartus_sh generate_version1.tcl" and have error:
Error:invalid command name "quartus_sh" Error: while executing Error:"unknown_original quartus_sh generate_version1.tcl" Error: ("eval" body line 1) Error: invoked from within Error:"eval unknown_original $cmd $args" Error: (procedure "::unknown" line 7) Error: invoked from within Error:"quartus_sh generate_version1.tcl"
Please, help me to solve my problem.
This zip file associated with this tutorial has an example that works ...
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104code_hawkins.zip
Look in the folder, ESC-104Code_Hawkins\dsp_tutorial\vhdl\boards\de0_nano\cyclone4\dsp_tutorial\scripts, at the scripts synth.tcl and synth_preflow.tcl
Cheers,
Dave
I would like to use a pre-flow script to modify design parameters. Typically I used top level Generics in my design and then assign these using the
Assignments/Settings/Default Parameters in Quartus. These appear as 'set parameter -name xxxx yy' in the project .qsf file.
When I try to use a similar syntax in my .tcl script to modify the parameters I am informed that I need to open a project first. I wish to modify the project that is already open/about to be compiled.
Any suggestions?
--- Quote Start ---
Any suggestions?
--- Quote End ---
Sure, read the script I referred to. It opens the project. Here's the bit you want ...
# ----------------------------------------------------------------- # Timestamp generic # ----------------------------------------------------------------- # # The project must be open before accessing generics if {!} { project_open -revision $revision $project } # Timestamp integer set timestamp # Top-level timestamp generic set_parameter -name TIMESTAMP $timestamp # Post an info message set timestamp_str set timestamp_hex post_message -type info "TIMESTAMP = $timestamp_hex ($timestamp_str)"
Cheers,
Dave
