17253 Discussions
A very new FPGA developer is very stuck. I think I have timing issues
Hi!
I am working on my first FPGA project ever. I have an Altera DE2 board and was following their "Quartus II introduction using verilog design" document.
Got through the tutorial with no issues(skipped simulation... probably my later issue)
Now, my first step for my learning is to make 4 leds light up and move across the red led array on the board.
here is the code in verilog(my first attempt so probably not that good)
module binaryShift( // this is the 27MHZ onboard clock input CLOCK_27, //push buttons input KEY, //dpdt switches input SW, //7-SEG Displays output HEX0, HEX1, HEX2, HEX3, HEX4, HEX5, HEX6, HEX7, //LEDs output LEDG, // LED Green output LEDR, // LED Red //GPIO CONNECTIONS inout GPIO_0, GPIO_1 ); // Blank the unused HEX displays assign HEX7 = 7'h7f; assign HEX6 = 7'h7f; assign HEX5 = 7'h7f; assign HEX4 = 7'h7f; assign HEX3 = 7'h7f; assign HEX2 = 7'h7f; assign HEX1 = 7'h7f; assign HEX0 = 7'h7f; //assign LEDR = 18'h12; reg paddle; always @(negedge KEY or negedge KEY) begin if(!KEY) begin case(paddle) 18'b000000000000001111 : paddle <= 18'b111100000000000000; 18'b000000000000011110 : paddle <= 18'b000000000000001111; 18'b000000000000111100 : paddle <= 18'b000000000000011110; 18'b000000000001111000 : paddle <= 18'b000000000000111100; 18'b000000000011110000 : paddle <= 18'b000000000001111000; 18'b000000000111100000 : paddle <= 18'b000000000011110000; 18'b000000001111000000 : paddle <= 18'b000000000111100000; 18'b000000011110000000 : paddle <= 18'b000000001111000000; 18'b000000111100000000 : paddle <= 18'b000000011110000000; 18'b000001111000000000 : paddle <= 18'b000000111100000000; 18'b000011110000000000 : paddle <= 18'b000001111000000000; 18'b000111100000000000 : paddle <= 18'b000011110000000000; 18'b001111000000000000 : paddle <= 18'b000111100000000000; 18'b011110000000000000 : paddle <= 18'b001111000000000000; 18'b111100000000000000 : paddle <= 18'b011110000000000000; default: paddle <= 18'b111100000000000000; endcase end else begin paddle <= ~paddle; end end assign LEDR = paddle; endmodule
the code seems pretty straight forward, but what happens is when I press the button the leds do follow the shifting pattern sort of, but after a press or 2 I get odd patterns not in the case statements... things like 10110111000000000....
My guess is that this is an issue in the timing because I get a lot of warnings about it. The problem now is I have 10.1 web edition which no longer has the vector waveform files like the tutorial shows. I have read through the forums that this question has been asked but only found people telling that the solution does exist and go find it. I know modelsim is the partial solution to doing the timing simulation but have not been able to figure out how to go from quartus to modelsim and back to the board. Has altera put out a tutorial for the newer version of quartus?
any help would be fantastic and greatly appreciated.
try initialise paddle to some known value.
--- Quote Start ---
--- Quote End ---
Tried, added:
initial begin paddle <= 18'b111100000000000000; end
No change, I have a ton of warnings(1123) with 2 critical warnings, both of which are "Timing requirements not met"
You should register the paddle on the clock edge, not on any other signal.
27MHz shouldn't be a problem for your code. Do you have timing constraints (sdc file)?
you are not using the clock.
No clock means no timing to analyse on registers and hence no violations of tSU/tH expected !!
I do not have a timing constraints file, How do I generate one? is that done in modelsim?
when you say register the paddle on the clock edge do you mean, somethign like
always @ (negedge KEY[2] and posedge clock)
I'm a little unsure of the right way to set up a clock... time to do some online hunting
always @(negedge clock_27)
try first without sdc then you can find a template at timequest resource centre (altera website)
Works perfectly :). here is the modified code if snyone else has this issue:
module binaryShift( // this is the 50MHZ onboard clock input CLOCK_27, //push buttons input KEY, //dpdt switches input SW, //7-SEG Displays output HEX0, HEX1, HEX2, HEX3, HEX4, HEX5, HEX6, HEX7, //LEDs output LEDG, // LED Green output LEDR, // LED Red //GPIO CONNECTIONS inout GPIO_0, GPIO_1 ); // Blank the unused HEX displays assign HEX7 = 7'h7f; assign HEX6 = 7'h7f; assign HEX5 = 7'h7f; assign HEX4 = 7'h7f; assign HEX3 = 7'h7f; assign HEX2 = 7'h7f; assign HEX1 = 7'h7f; assign HEX0 = 7'h7f; //assign LEDR = 18'h12; reg paddle; reg pressed; initial begin paddle <= 18'b111100000000000000; pressed <= 1'b0; end always @( negedge CLOCK_27) begin if (KEY) begin pressed <= 1'b0; end if(!KEY && !pressed) begin pressed <= 1'b1; case(paddle) 18'b000000000000001111 : paddle <= 18'b111100000000000000; 18'b000000000000011110 : paddle <= 18'b000000000000001111; 18'b000000000000111100 : paddle <= 18'b000000000000011110; 18'b000000000001111000 : paddle <= 18'b000000000000111100; 18'b000000000011110000 : paddle <= 18'b000000000001111000; 18'b000000000111100000 : paddle <= 18'b000000000011110000; 18'b000000001111000000 : paddle <= 18'b000000000111100000; 18'b000000011110000000 : paddle <= 18'b000000001111000000; 18'b000000111100000000 : paddle <= 18'b000000011110000000; 18'b000001111000000000 : paddle <= 18'b000000111100000000; 18'b000011110000000000 : paddle <= 18'b000001111000000000; 18'b000111100000000000 : paddle <= 18'b000011110000000000; 18'b001111000000000000 : paddle <= 18'b000111100000000000; 18'b011110000000000000 : paddle <= 18'b001111000000000000; 18'b111100000000000000 : paddle <= 18'b011110000000000000; default: paddle <= 18'b111100000000000000; endcase end else if (!KEY) begin paddle <= ~paddle; end end assign LEDR = paddle; endmodule
now, So I added the "pressed" register so that it didn't keep cycling the case statements while the button was pressed, is there a better way to do this code?
Like I said , I am still very much learning and any critique of my code will be very much appreciated.
That is very good for a beginner.
The issue was timing but due to logic hazards of asynchronous design.
Asynchronous design can be very very fast but needs exceptional skills to master it against hazards. Using the clock as sampling signal, decision are done on the edge when logic levels have settled... fpgas are meant for clocked design (RTL)
Thanks for all your help Kaz!
