17249 Discussions
Quartus II can't find package during synthesis
Hi all!
In a design I am currently working on, I need to manually instanciate a Stratix IV I/O buffer.
So here is my code:
library stratixiv; use stratixiv.stratixiv_components.all; a_in : stratixiv_io_ibuf generic map ( differential_mode => "false", bus_hold => "false", lpm_type => "stratixiv_io_ibuf" ) port map ( i => a, o => a_int );
This works fine in simulation (ModelSIM DE 6.6a), but during synthesis with Quartus II 10.1 I get the following error:
--- Quote Start ---
Error (10481): VHDL Use Clause error at ns_io.vhd(26): design library "stratixiv" does not contain primary unit "stratixiv_components" File: /home/ns/ns_io/src/ns_io.vhd Line: 26
Error (10800): VHDL error at ns_io.vhd(26): selected name in use clause is not an expanded name File: /home/ns/ns_io/src/ns_io.vhd Line: 26
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 330 megabytes
Error: Processing ended: Thu Apr 28 13:23:30 2011
Error: Elapsed time: 00:00:08
Error: Total CPU time (on all processors): 00:00:07
--- Quote End ---
I could find the package file stratixiv_components.vhd several time:
/opt/altera10.1/modelsim_ase/altera/vhdl/src/stratixiv/stratixiv_components.vhd
/opt/altera10.1/quartus/eda/fv_lib/vhdl/stratixiv/stratixiv_components.vhd
/opt/altera10.1/quartus/eda/sim_lib/stratixiv_components.vhd
/opt/altera10.1/quartus/libraries/vhdl/wysiwyg/stratixiv_components.vhd
I could fix this by removing the use clause at the beginnning of my file and adding the file /opt/altera10.1/quartus/eda/synthesis/stratixiv.vhd to the sources of the project, but this is not clean.
any idea on why the package is not found during synthesis?
Thx,
-Julien
for whatever reason Quartus doesn't like use stratixiv.stratixiv_components.all; but use stratixiv.all; seems to work. i chose to turn it off for synthesis, simulation will still pick up the library
other than that it looks like you just need a component declaration for the I/O buffer. this works:
library ieee; use ieee.std_logic_1164.all; -- synthesis translate_off library stratixiv; use stratixiv.stratixiv_components.all; -- synthesis translate_on entity test_io is port ( a : in std_logic; b : out std_logic ); end entity; architecture rtl of test_io is COMPONENT stratixiv_io_ibuf GENERIC ( bus_hold : STRING := "false"; differential_mode : STRING := "false"; simulate_z_as : STRING := "Z"; lpm_type : STRING := "stratixiv_io_ibuf" ); PORT ( dynamicterminationcontrol : IN STD_LOGIC := '0'; i : IN STD_LOGIC := '0'; ibar : IN STD_LOGIC := '0'; o : OUT STD_LOGIC ); END COMPONENT; begin a_in : stratixiv_io_ibuf generic map ( differential_mode => "false", bus_hold => "false", simulate_z_as => "Z", lpm_type => "stratixiv_io_ibuf" ) port map ( dynamicterminationcontrol => '0', i => a, ibar => open, o => b ); end rtl;
Thx but actually what we try to do is to avoid declaring components, that's why we want to use the package.
Has anyone the explanation please?
Thx
