17268 Discussions
ALTERA QUARTUS II + Signal TAP + Change triggers without recomipling...
Hello guys!
One question, Is there any possibility to change the trigger options in signal TAP without recompile the entire project? I don't want to do an incremental compilation or rapid compilation. My design is not prepared for an incremental compilation and the rapid compilation does not work...
It is possible to change the Basic Trigger Conditions without recompiling. Could you give more details of what you need to do? Signal Tap will tell you to recompile the project when you change something that requires it.
Thiago
