Hi i am a beginner . I need help with implementing sha 256 on altera cyclone II board so that i can use it as a testbed to study side channel analysis. I am looking for a fully working code , that can be programmed on cyclone II device.
thanksLink Copied
Requests like this usually dont work. It makes people think you are lazy.
Have a look on opencores.org for a start, and maybe google? If you cannot find it there, you may have to implement it yourself.- Mark as New
--- Quote Start --- Requests like this usually dont work. It makes people think you are lazy. Have a look on opencores.org for a start, and maybe google? If you cannot find it there, you may have to implement it yourself. --- Quote End --- Hi Thanks for the reply. For my project we are using public codes , our main aim is to do some side channel analysis on the cyclone II implementation. http://opencores.org/websvn,filedetails?repname=nfhc&path=%2fnfhc%2ftrunk%2fsha256%2fsha256.vhdl i checked this code . Can someone tell me how can i send 32 bit input to the fpga board ? thanks
how about RS232?
