I am trying to use ALTPLL megafunction in my design. I generated the IP using the megafunction IP manager. then i've instantated that in my top-level design and hooked it up in the following manner.
module designTop ( inclk0, PLL_RESET, PLL_LOCKED, SYSCLK, CR4CLK ); input inclk0, PLL_RESET; output PLL_LOCKED, SYSCLK, CR4CLK; pcst_sysclkpll pcst_sysclkpll_inst ( .areset ( PLL_RESET ), .inclk0 ( inclk0 ), .c0 ( SYSCLK ), .c1 ( CR4CLK ), .locked ( PLL_LOCKED ) ); endmodule I get the following error: Info: Input port INCLK[0] of node "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" is driven by inclk0~buf0 which is COMBOUT output port of LOGIC_CELL_COMB type node inclk0~buf0 Error: Clock input port inclk[0] of PLL "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block Even though i've connected the inclk0 to a top-level input pin, Quartus is placing a buffer before the inclk0 pin of the PLL resulting the above error. how do i resolve this? Thanks連結已複製
6 回應
i am using vesion 8.0 SP1, build 07/10/2008 SJ Full version.
I have tried the following things in my end and still have the issue: A. Assigning pin location thru synthesis directive instead of thru pin planner: input inclk0 /* synthesis chip_pin = "AA1" */; // input Clock I got the same error. B. Driving the PLL input thru altclkctrl in the following manner: altclkctra pcst_altclkctrl_inst1 ( .inclk (inclk0), .outclk (pll_clkin) ); pcst_sysclkpll pcst_sysclkpll_inst ( .areset ( PLL_RESET ), .inclk0 ( pll_clkin ), .c0 ( SYSCLK ), .c1 ( CR4CLK ), .locked ( PLL_LOCKED ) ); I got the following error: Error: Clock input port inclk[0] of PLL "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block Info: Input port INCLK[0] of node "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" is driven by altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|wire_clkctrl1_outclk which is OUTCLK output port of CLKCTRL type node altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|clkctrl1 eventhough it is driven by CLKCTRL node, i get the same error and dont understand why.--- Quote Start --- i am using vesion 8.0 SP1, build 07/10/2008 SJ Full version. I have tried the following things in my end and still have the issue: A. Assigning pin location thru synthesis directive instead of thru pin planner: input inclk0 /* synthesis chip_pin = "AA1" */; // input Clock I got the same error. B. Driving the PLL input thru altclkctrl in the following manner: altclkctra pcst_altclkctrl_inst1 ( .inclk (inclk0), .outclk (pll_clkin) ); pcst_sysclkpll pcst_sysclkpll_inst ( .areset ( PLL_RESET ), .inclk0 ( pll_clkin ), .c0 ( SYSCLK ), .c1 ( CR4CLK ), .locked ( PLL_LOCKED ) ); I got the following error: Error: Clock input port inclk[0] of PLL "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block Info: Input port INCLK[0] of node "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" is driven by altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|wire_clkctrl1_outclk which is OUTCLK output port of CLKCTRL type node altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|clkctrl1 eventhough it is driven by CLKCTRL node, i get the same error and dont understand why. --- Quote End --- Hi, I run your code with Quartus II 8.0 SP1 (Full Version) ,including the pin assignment for the input clock, and it works fine. Did also constrain the other pins ?
After i deleted all my pin assignments and ran, i didn't get the error. didn't understand why my assignments was causing the above error. But now it is resolved. Thanks everyone for the timely tips.
