ALTPLL synthesis issue
I am trying to use ALTPLL megafunction in my design. I generated the IP using the megafunction IP manager. then i've instantated that in my top-level design and hooked it up in the following manner.
module designTop (
inclk0, PLL_RESET, PLL_LOCKED, SYSCLK, CR4CLK );
input inclk0, PLL_RESET;
output PLL_LOCKED, SYSCLK, CR4CLK;
pcst_sysclkpll pcst_sysclkpll_inst (
.areset ( PLL_RESET ),
.inclk0 ( inclk0 ),
.c0 ( SYSCLK ),
.c1 ( CR4CLK ),
.locked ( PLL_LOCKED )
endmodule
I get the following error:
Info: Input port INCLK[0] of node "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" is driven by inclk0~buf0 which is COMBOUT output port of LOGIC_CELL_COMB type node inclk0~buf0
Error: Clock input port inclk[0] of PLL "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block
Even though i've connected the inclk0 to a top-level input pin, Quartus is placing a buffer before the inclk0 pin of the PLL resulting the above error. how do i resolve this?
What device are you using and which pin is inclk0 assigned to?
Iam using startixIII EP3SL340F1517C3. i've assigned it to pin_AA1 which is a dedicated CLK pin (CLK8n) and IOBank_5C.
I have just replicated your design and PLL including pin placement and do not have the error that you observed.
What version of Quartus are you running?
Rgds
V
i am using vesion 8.0 SP1, build 07/10/2008 SJ Full version.
I have tried the following things in my end and still have the issue:
A. Assigning pin location thru synthesis directive instead of thru pin planner:
input inclk0 /* synthesis chip_pin = "AA1" */; // input Clock
I got the same error.
B. Driving the PLL input thru altclkctrl in the following manner:
altclkctra pcst_altclkctrl_inst1 (
.inclk (inclk0),
.outclk (pll_clkin) );
.inclk0 ( pll_clkin ),
.c0 ( SYSCLK ),
.c1 ( CR4CLK ),
I got the following error:
Info: Input port INCLK[0] of node "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" is driven by altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|wire_clkctrl1_outclk which is OUTCLK output port of CLKCTRL type node altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|clkctrl1
eventhough it is driven by CLKCTRL node, i get the same error and dont understand why.
--- Quote Start ---
.inclk (inclk0),
.c0 ( SYSCLK ),
.c1 ( CR4CLK ),
--- Quote End ---
I run your code with Quartus II 8.0 SP1 (Full Version) ,including the pin assignment for the input clock, and it works fine. Did also constrain the other pins ?
After i deleted all my pin assignments and ran, i didn't get the error. didn't understand why my assignments was causing the above error. But now it is resolved. Thanks everyone for the timely tips.
