17244 Discussions
ALTSHIFT_TAPS megafunction in Quartus II 9.1
Does Quartus II 9.1 Web Edition supports SHIFT_TAPS mega function. I could not find it in the mega functions wizard list.
I am trying to create a long shift register.
What device are you targeting? It should be in there.
Note that Quartus synthesis does an excellent job of finding shift-registers and inferring altshift_taps, so there generally isn't any reason to manually instantiate the megafunction. The one thing to avoid in the RTL is a clear on the shift register(asynchronous or synchronous) since the memory block can't have its contents cleared in one cycle. I think altshift_taps inference has a way around this, but it's probably better to avoid the clear if you can(and most shift-registers can).
I am targeting Cyclone III EP3C25F324C8. If synthesis tool automatically infers ALTSHIFT_TAPS for shift registers, It should be captured in some report file. Which report file should I look for.
I am a bit unsure about your issue.
shift registers are not a hardwired case to be inferred like say multipliers.
Unless you mean shift implemented in ram. In that case you can look at resource section of fitter (resource by entity)
The .map.rpt has it. Just search on "altshift". I believe there is a message when inferred, there is a section on inferred megafunctions, and it will be in the hierarchy section.
