- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Since I updated the tools to 14.0, I cannot compile OpenCL kernels that compiled fine with the 13.1 release. I get the following output :aoc -v --report kernel.cl
aoc: Environment checks are completed successfully.
You are now compiling the full flow!!
aoc: Selected target board c5soc
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Compiling....
aoc: Linking with IP library ...
; Estimated Resource Usage Summary ;
; Resource + Usage ;
; Logic utilization ; 30% ;
; Dedicated logic registers ; 13% ;
; Memory blocks ; 29% ;
; DSP blocks ; 20% ;
aoc: First stage compilation completed successfully.
aoc: Setting up project for QXP preservation flow....
And that's it. The program stays in this state for ever (or at least, for 60+ hours which is abnormal for a kernel that compiled under 1 hour in 13.1). The first phase (kernel analysis and .aoco generataion) works fine, but the compilation to .aocx fails to complete and the quartus_sh_compile.log is empty... What am I missing ? Did anyone else face a similar issue with the new release ? Thanks for your help
- Marcas:
- Intel® High Level Design
Link copiado
9 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Maybe just cancel and restart it.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Oh, I forgot to mention it, but I tried the command (and variants) a few times, and on different files. :)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I just tried running the command as root and it worked !
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Can you please attach <kernel>/<kernel>.log for the hung run?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I went back to using aoc v13.1, and I didn't keep any log from v14.0. If I remember correctly, it contained the same as the console output. Working as root corrected the problem, maybe it was just due to permission issues ?- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I also suspect the permissions issue. I just wanted to know which underlying tool tripped on the issue.
Did you install the AOCL tool as root or as a regular user?- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Probably as root ; unfortunately I can't remember. Using the tools only as root is good enough for me, though :).
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- Hello, Since I updated the tools to 14.0, I cannot compile OpenCL kernels that compiled fine with the 13.1 release. I get the following output :
aoc: Compiling....
And that's it. The program stays in this state for ever (or at least, for 60+ hours which is abnormal for a kernel that compiled under 1 hour in 13.1). The first phase (kernel analysis and .aoco generataion) works fine, but the compilation to .aocx fails to complete and the quartus_sh_compile.log is empty... What am I missing ? Did anyone else face a similar issue with the new release ? Thanks for your help --- Quote End --- I have same problem. I am working as Root user but I am still not able to compile it. Funny thing is yesterday I compile Hello_world example and today I tried again to do same and Its not working today. Could anyone help me for it?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I'm having the same problem. I could successfully compile my kernel using the 14.0 release. However, compilation fails when using the same kernel and the 16.0 release (the program seems to loop and quartus_sh_compile.log is empty). I've also tried the 15.1 release and working as root, but the problem still persists. Does anyone know how to solve this issue? Thanks in advance.
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
