17268 Discussions
ASSERT statement using & operator
Please consider the following code:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.my_package.all; entity my_mux is generic(N: integer := 8); port(x: in std_logic_vector(N-1 downto 0); a: in std_logic_vector(ceil_log2(N)-1 downto 0); y: out std_logic); end my_mux; architecture arch of my_mux is begin aviso: assert false report "size of a is " & a'length severity note; gen: for i in 0 to N-1 generate y <= x(i) when (a = std_logic_vector(to_unsigned(i, ceil_log2(N))) and (i < (N-1))) else 'Z'; end generate; end arch;
Regarding the line "report", I can´t synthesize this code. It is produced an error.
Everything like report "message 1" & "message 2" (considering messages 1 and 2 only text messages) it synthesizes well and produces me the desired note message.
If I try report "message" & xxxx, where xxxx is N, a'length, or any value different than a simple text, it produces an error.
error (10327): vhdl error at mux.vhd(18): can't determine definition of operator ""&"" -- found 0 possible definitions
How can I see my desired message?
Jaraqui
it is because "size of a is" is a string, and a'length is an integer type. You cannot concatenate them directly. You have to convert the integer to a string.
try this:
aviso: assert false report "size of a is " & integer'image(a'length) severity note;
perfect! Thanks!
