Hello All,
How can I read the accelerometer data in VHDL? I have current ports relate to the accelerometer but with no luck in actually using them:- I2C_SCLK
- I2C_SDAT
- G_SENSOR_CS_N
- G_SENSOR_INT
If you look at the example code in the:
Demonstration/DE0_NANO_GSensor directory you can see how they use the I2C interface to read values from the Accelerometer Good luck, I'm still trying to make sense of this all also. -D- Mark as New
Thank you for your tip:)
