17256 Discussions
Best way to code flop w/asynch reset?
Hi - I've lots of experience in Verilog, but am learning VHDL.
Question: Is this...
process(clk,rst_l) begin
if rst_l = '0' then
sig <= '0';
elsif rising_edge(clk) then
sig <= expression;
end if;
end process;
the best way to do the equivalent of
always @(posedge clk or negedge rst_l) begin
if (!rst_l) sig <= 0;
else begin
sig <= expression;
end
end
(i.e., flop with asynch reset)
I'm asking because in Verilog it's sort of by convention that if you do it -just that way- then all the synthesizers infer you want an asynch flop and the else expression is clocked. I want to make sure I'm doing it the most general way (i.e., least likely for a synth to mis-interpret) for VHDL.
THANKS!
/j
Yep, that's the correct way.
Hey - thanks rbugalho - I try to research these myself but if I have any other hard ones I'll post
best!
/j
Two additional remarks.
- You can browse the VHDL templates in the Quartus editor to learn about common language constructs.
- There's a specification IEEE 1076.6 ieee standard for vhdl register transfer level (rtl) synthesis trying to define a VHDL subset that should be understood by all synthesis tools. Although Quartus is not 100% following this (newer) standard, it almost applies to Quartus synthesis.
thanks FyM
If I have questions about what VHDL synthesizes to, I use the Quartus RTL viewer and look at what the code synthesizes to :)
Tools->Netlist Viewers->RTL Viewer
Cheers,
Dave
last time I looked, Quartus synthesizes everything to ALM/LUTs - not as easy to read as an ASIC gate-level netlist 8-}
--- Quote Start ---
--- Quote End ---
But for things like asynchronous reset, synchronous reset, enable, clock enable, etc., its very useful for seeing whether the VHDL codes to a single signal that connects to a register port, or whether a mux is created in front of the register.
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
The RTL viewer doesn't show ALM/LUTs; it shows the design using logic blocks, big (ie, multiplexers, adders, etc) and small (ANDs, ORs, etc).
It's a great view to understand how the synthesis tool is interpreting your HDL.
hm - well to be honest I haven't tried it in a long time
thanks!
/j
--- Quote Start ---
--- Quote End ---
The first thing I do after a Analysis ans Synthesis is inspecting the RTL-diagram!
I tend to divide my design in such a way that I get (if possible) small RTL-diagrams with only blocks, and only at the lowest level the logic will become visible. I even code a state machine in its own .vhd file so I can see what the data-flow is, without the state-machine logic cluttering the diagram. So I developed sub-modules for almost every task like counting up or down, multiplexing std_logic_vectors, priority encoders, etc., anything as long as it helps simpliying the RTL-diagram to an easy-to-follow collection of connected blocks.
--- Quote Start ---
--- Quote End ---
Excellent advice! A man after my own coding style.
Other arguments for this approach are that you can create testbenches for each submodule, and perform code coverage.
The other argument for splitting a state machine away from its data path logic (also known as FSM-D, or finite-state-machine data path) is that it is much easier to document. For example, FSMs drawn as algorithmic state machine (ASM) charts map directly to the case and if-then logic of both Verilog and VHDL.
For examples of ASM charts and block diagrams that are analogous to the RTL diagrams, see:
http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf
Cheers,
Dave
