17264 Discussions
Access to svf2jam software
ekatsma
I'm replacing an Intel; EPM3032ATI44-10N with a Microchip; ATF1502ASV-15AU44. I have successfully uploaded software to the Microchip CPLD by using the ATDH1150USB tool and Microchips POD2JED software and was able to confirm that it works. Going forward I plan to upload the software with a Jam player. I am able to convert the JED file that I used to program the Microchip device into an SVF file, but I can't get access to the svf2jam software on Intel in order to convert that into a jam file because the software is discontinued. How can I get access to this software in order to generate a .jam file?
WZ2
Hi there,
We just receive this case, and we will help you resolve your problem as soon as possible~
WZ2
Hi ekatsma,
Since this svf2jam tool is discontinued, to request the usage, you will need to talk to your Intel FPGA / Sales Rep who will be able to formally request it for you. We can not share the utility through Community.
You may also try to find third-party tools. These two file types are both jtag standard, so there should be other software other than Intel's.
