17267 Discussions
Active HDL Simulation Script Error
cosx
Hi everyone,
I came across an issue when using active hdl to simulate a project.
The script of error is shown in the attachment file for your reference.
Among these errors, one typical notification is "Library ( ) does not exist" and the braket "( )" contains the simulated project location.
I doubt something goes wrong with my library paths, but do not know how to fix them.
I have also tried to attach library from the installed location but does not work at all.
Could anyone please kindly help me with this situation?
Thanks!
Mingqiang
RichardTanSY_Altera
Have you gone through the simulation flow as stated in the document below?
Please try the simulation flow and let me know if the issue persists.
Quartus Standard:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-tp-simulation.pdf#page=30
cosx
Hi there,
Thank you for your documentation.
My Quartus is a lite edition and I guess the second step in this documentation has been automatically done when I run tools->run simulation tools->gate level simulation.
Something goes wrong with the nativelink file and I have attached it for your references.
I guess it has something to do with my Active-HDL installation path, but do not know solution.
Thank you!
Best,
Mingqiang
cosx
Hi there,
Sorry for disturbing you again!
May I kindly ask if you have know any solutions about the nativelink issues in my attachment?
Thanks!
Mingqiang
RichardTanSY_Altera
Sorry for idling for some time, do you still need help on this?
RichardTanSY_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Shyan Yew
cosx
Hi there,
I have finished the simulation using modelsim already.
Could you please turn this support off?
Thank you very much!
Best Wishes,
Mingqiang
