When I start “Start Test Bench Template writer” I receive this error message
Cannot start test bench template writing—no EDA simulation tool specified In the EDA Tool Options I specified “C:\altera\91sp2\modelsim_ase\win32aloem” for ModelSim and ModelSim-Altera. Still I’m getting same message. Altera version Quartus 9.1 Modelsim Version: Altera Starter Edition 6.5b Any ideas?Link Copied
try choosing ModelSim-Altera in Assignments > Settings > EDA Tools > Simulation, then running the writer
--- Quote Start --- try choosing ModelSim-Altera in Assignments > Settings > EDA Tools > Simulation, then running the writer --- Quote End --- Is there any reason the file extension is vht? Should I rename it to vhd to work with the ModelSim?
.vht is just to differentiate that the file is a test bench, ModelSim will compile it without a problem
