17261 Discussions
Altera-USB Blaster II is unsigned and difficult to install on Windows 10.
dond
One has to go through much trouble to install the Altera-USB Blaster II driver because it is unsigned. This really should be solved by Intel who is distributing the driver software. It wouldn't be hard to have a signed version and it would help your customers very much if you did.
NurAiman_M_Intel
We apologize for the inconveniences.
That might be due to issue with USB Blaster. Due to the expiration of the digital signature certificate of the Intel® FPGA Download Cable I (formerly referred to as USB Blaster I download cable) and the Intel® FPGA Download Cable II (formerly referred to as USB Blaster II download cable) drivers for Windows* operating system, the installation process of the drivers may fail.
We have publish a KDB for user to follow:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2021/why-does-the-intel--fpga-download-cables-drivers-installation-fa.html
Aiman
dond
Yes, this solution is similar to the one I employed. It is a work-around. It would be best if you updated your website with a driver installation that works without this work-around. Thank you for your time.
