17255 Discussions
Altera monitor program terminal device problem
Hi guys,
I have some troubles with the Altera Monitor Program.
As I write in the title, when I create a new project, I select all the needed parameters and then,
when I am on the "Specify system parameters" table, the Terminal device drop-down menu can't see the device
and it show me " <none> " and I can't select any other things... Someone can help me ?
I use the DE2 board with the latest version that support Cyclone II (Quartus 13.0sp1 and Altera Monitor Program 13.0) on a windows 7 64Bits machine.
Thank you,
Regards.
