17254 Discussions
"ip-generate FAILED" after upgrading AOC
I recently attempted to upgrade my Altera OpenCL SDK to version 14.1. Everything seemed to complete successfully so then I attempted to compile a test program. When I attempted to compile a program with this new version, I received the following message.
C:\Users\Me\workspace > aoc --board p385_mac_a7 -v hello_world.cl aoc: Environment checks are completed successfully. You are now compiling the full flow!! aoc: Selected target board p385_mac_a7 aoc: Running OpenCL parser.... aoc: OpenCL parser completed successfully. aoc: Compiling.... aoc: Linking with IP library ... aoc: First stage compilation completed successfully. Error: ip-generate FAILED. Refer to hello_world/hello_world.log for details.
Here is what the log file had about the error:
--- Quote Start ---
2014.12.18.13:55:53 Info: set_validation_property AUTOMATIC_VALIDATION false
2014.12.18.13:55:53 Info: add_instance kernel_system kernel_system
2014.12.18.13:56:01 Info: add_connection board.kernel_clk kernel_system.clock_reset
2014.12.18.13:56:01 Info: add_connection board.kernel_clk2x kernel_system.clock_reset2x
2014.12.18.13:56:01 Info: add_connection board.kernel_reset kernel_system.clock_reset_reset
2014.12.18.13:56:01 Info: add_connection kernel_system.kernel_mem0 board.kernel_mem0
2014.12.18.13:56:01 Info: add_connection kernel_system.kernel_mem1 board.kernel_mem1
2014.12.18.13:56:01 Info: add_connection board.kernel_irq kernel_system.kernel_irq
2014.12.18.13:56:01 Info: add_connection board.kernel_cra kernel_system.kernel_cra
2014.12.18.13:56:01 Info: add_connection board.acl_internal_snoop kernel_system.cc_snoop
2014.12.18.13:56:01 Info: add_connection board.kernel_clk kernel_system.cc_snoop_clk
2014.12.18.13:56:01 Info: save_system
'ip-generate' is not recognized as an internal or external command,
operable program or batch file.
--- Quote End ---
Has anyone seen anything like this or know what could be the cause of it?
I did add the following path in the PATH environment variable to make sure ip-generate was found:
[root@localhost iso]# find /opt/altera/14.0 -name ip-generate
/opt/altera/14.0/quartus/sopc_builder/bin/ip-generate
export PATH=$PATH:/opt/altera/14.0/quartus/sopc_builder/bin/ip-generate
G
zmiller: This seems to be an issue with Windows in 14.1. As a workaround add sopc_builder/bin to your PATH: set PATH=c:\altera\14.1\quartus\sopc_builder\bin;%PATH%
gigi: You're referring to 14.0 Linux. I don't think you needed to this in Linux for either 14.0 or 14.1
