Dear,
When compiling a simple project with the attached pll as a toplevel i get the following error because i try to use output frequence parameter in stead of device and multiply parameters. Q9.1--> Error: PLL "altpll:altpll_component|altpll_ign2:auto_generated|pll1" has port CLK[0] connected but parameters clk0_multiply_by and/or clk0_divide_by are either unspecified or set to 0 I really want to define the output frequency in stead of devision and multiply factors. Can somebody make this work? Thx, Johannes more info: I want to create a pll based on a vhdl file not using the gui because I want to do batch compilation of pll's with different output frequency settings. This is what i did: I started from a megawizard generated file. The project compiles fine. I looked in the autamtically generated file and saw that a clock devision and multiplier parameter was created (although is specified a frequency in the megawizard): " clk0_divide_by : NATURAL; clk0_multiply_by : NATURAL; " I'd like to work with the output frequency parameter instead as stated in the "The Phase-Locked Loop (ALTPLL) Megafunction User Guide" "CLK[]_OUTPUT_FREQUENCY: Integer: Specifies the output frequency of the corresponding output clock port, CLK[9..0].This parameter is ignored if the corresponding CLK[9..0] port is not used. This parameter is unavailable if multiplication or division factors are specified. If omitted, the default is 0." When compiling a simple project with the attached pll as a toplevel i get the following error: --> Error: PLL "altpll:altpll_component|altpll_ign2:auto_generated|pll1" has port CLK[0] connected but parameters clk0_multiply_by and/or clk0_divide_by are either unspecified or set to 0 I guess it has something to do with the statement in the user guide at the devide/multiply paramerters: "Specifies the integer division factor for the VCO frequency of the corresponding output clock port, CLK[9..0] port. The parameter value must be greater than 0. Specify this parameter only if the corresponding CLK[9..0] port is used; however, it is not required if a clock settings assignment is specified for the corresponding clk[9..0] port. If omitted, the default is 0." What Clock Settings assignment???? Kind regards, JohannesLink Copied
You didn't clarify, if you manually edited the MegaFunction generic parameters or if the wizard generated file causes an errot in Quartus compilation?
The megawizard generated file compiles fine, but it uses the multiply and devide parameters in stead of the output frequency parameter.
When i try to adapt the generated file manually (as in the attached file) it goes wrong. I simply ommit the clk0_divide_by and the clk0_multiply_by parameters and replace it with the clk0_output_frequency parameter and it fails to compile. Regards, Johannes- Mark as New
Judging by your own work I can say:
The frequency parameter need to be converted to PLL parameters of mult/div and not the other way round. PLLs ar based on these figures for their internal counters. Frequency entry is just a user convenience. You will need to convert frequency manually to mult/div factors if you don't want GUI. Remember not all frequencies are possible. Only those that fit the mult/divide values.- Mark as New
I agree, that according to the MegaFunction user manual the clkx_output_frequency parameter should work, but it seem to be unsupported. I wasn't aware of, because I'm using mutiplier/divider also in manual PLL instantiation.
Dear,
Thx for the effort, I think i worked it out. You can use clkx_output_frequency parameter IF you define the multiply and devision factors in the SDC file. Make a clock and derived clock for the pll clocks. It seems that one needs either way to supply Quartus with multiply and devision factors. So i have to agree with kaz and calculated myself the mult and div factors. This is not so easy as it seams because their are a lot of restricions eg. Fvco max/min, m max, n max, c max,.... And it is frustrating because i know Quartus CAN do it (it does it in the megawizard GUI!). Not very convenient for the user :-( Anyhow: if their are more tips to tackle this problem in an elegant way just add them to this tread! I will be gratefull. Have a nice old to new! Johannes
