- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Internal Error: Sub-system:AMERGE,File:/quartus/atm/amerge/amerge_kpt_op.cpp,Line:390
kpt_mgr->save_keypoints_db(map_kpt_db->get_name(),map_save_file_name) Stack Trace: 0x3E2AF: amerge_mini_merge+0x3AECF(atm_merge) End-trace Quartus II Version 9.0 Build 132 02/25/2009 SJ Full Version I've met this problem, and don't know how to solve it. If you know why, will you give me the resolusion or some advice? Many thanks!Link copiado
2 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
1. you can try deleting db and incremental_db in the project directory
2. if that doesn't work you should update to a newer Quartus II- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
So many thanks PanCake! Deleting the db and incremental db worked for me!
Rgds Balu
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
