Array Declaration cases
Hi All,
Is there a difference in the following declarations:
case1:
reg [3:0][7:0] abc;
case2:
reg [3:0] abc [7:0];
case3:
reg abc [3:0][7:0];
What's the difference?
Thank you!
Putting dimensions before the variable name is a packed array. packed arrays can only be made of bit types.
Unpacked arrays have the dimensions after the name. They can be any type.
http://www.asic-world.com/systemverilog/data_types10.html
Thanks Tricky!
I need to declare a multi-dimension array of enumerated elements...
Could you please take a look in this thread: https://alteraforum.com/forum/showthread.php?t=57903
Thank you again!
