Array en VHDL
Hi everybody !
I want to add(xor) data with CD in shape array and the result would be S
Can you help me correcting this code :
library ieee;use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity cdm is port ( clk : in std_logic ; rst : in std_logic ; data: in std_logic ; odata: out std_logic ; CD : in std_logic_vector(15 downto 0) ; isis :out integer range 0 to 3 ; S :out std_logic_vector(3 downto 0 )); end entity ; architecture beh of cdm is type tab is array(3 downto 0)of std_logic_vector(15 downto 0); signal i :integer range 0 to 3 ; signal idata :std_logic ; signal itab :tab ; begin code :process(clk,rst) begin if(rst='1')then itab(i)<="0000" ; else if(clk'event and clk='1')then itab(i)<= not(CD(15 downto 12)xor (data)); S(i)<=itab(i); i<= i+1 ; itab(i)<=not(CD (11 downto 8) xor(data)); S(i)<=itab(i); i<=i+1 ; itab(i)<=not( CD(7 downto 4) xor (data)); S(i)<=itab(i); i<=i+1; itab(i)<=not( CD(3 downto 0) xor (data)); S(i)<=itab(i); i<=i+1 ; if i=3 then idata<=data ; end if ; end if ; end if ; end process ; isis<=i; odata<=idata ; end architecture ;
Thank you in advance for your answer
What is the problem?
I think, your i signal is never assigned a value. You're missing a loop or something like that to assign a value to i to begin with. Also itab is always assigned the last value.
I suggest you think about the code a little more.
I suggest:
inside clocked process
if reset then
i <= 0;
i <= i+1;
case i is
when 0 => s(0) <=not(CD(15 downto 12)xor (data));
when 1 => s(1) <= ...;
when 2 =>
when 3 =>
corrected S
if reset then
i <= 0;
i <= i+1;
case i is
when 0 => s <=not(CD(15 downto 12)xor (data&data&data&data));
when 1 => s <= ...;
when 2 =>
when 3 =>
You want that I make like that :
library ieee;
entity cdm is
--generic (
-- width : natural :=4);
port (
end entity ;
--type tab is array(3 downto 0)of std_logic_vector(15 downto 0);
--signal itab :tab ;
begin
begin
if(rst='1')then
i<="0000" ;
else
i<=i+1 ;
case i is
when 0 =>s(0)<=not(CD(15 downto 12) xor (data));
when 1 =>s(1)<=not(CD(11 downto 8) xor (data));
when 2 =>s(2)<=not(CD(7 downto 4) xor (data));
when 3 =>s(3)<=not(CD(3 downto 0) xor (data));
if i=3 then
idata<=data ;
end if ;
end case ;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end architecture ;
?? ! Thank you in advance
try this
if(rst='1')then i <= 0 ; elsif(clk'event and clk='1')then i <= i + 1 ; case i is when 0 => s <= not(CD(15 downto 12) xor (data&data&data&data)); when 1 => s <= not(CD(11 downto 8) xor (data&data&data&data)); when 2 => s <= not(CD(7 downto 4) xor (data&data&data&data)); when 3 => s <= not(CD(3 downto 0) xor (data&data&data&data)); odata<=data ; end case ; end if ; end process ; end architecture ;
I thank that it is necessary to leave the 1st program and inside it will be necessary to make out a will "data" (1 or 0)
non ?
--- Quote Start ---
non ?
--- Quote End ---
I don't think even "Tricky" can understand your post. Why don't you just simulate and adjust things. That is how we all work and learn.
write compile simulate and repeat cycle
There are some errors :
Error (10381): VHDL Type Mismatch error at cdmoin.vhd(34): indexed name returns a value whose type does not match "std_ulogic", the type of the target expression
Error (10327): VHDL error at cdmoin.vhd(34): can't determine definition of operator ""&"" -- found 0 possible definitions
--- Quote Start ---
--- Quote End ---
I'm sorry but I don't well understood !
You didnt copy Kaz's code properly. It compiles just fine for me.
Like Kaz said - why not try and learn the code yourself, rather than have someone do it for you?
is that error in this file or another? also as a sidenote, putting your code in code tags improves readability.
hi guys !!
i solved my problem but i have another is near of ""Type Re is array ""
can you help me please !!
library ieee;
entity cdma_testbipo is
port (
type Re is array(0 to 3)of integer range 0 to 15;
signal CD: Re ;
S :out integer range -8 to 7 );
end entity ;
architecture beh of cdma_testbipo is
type RAM is array (0 to 3) of integer range -8 to 7;
signal code : RAM;
begin
code(0)<=CD(15 downto 12);
code(1)<=CD(11 downto 8) ;
code(2)<=CD(7 downto 4) ;
code(3)<=CD(3 downto 0) ;
bpsk :process(clk,rst)
begin
if(rst='1')then
i<= 0;
else
i<=i+1 ;
if(idata='0') then
s<=-code(i);
else
s<=code(i);
end if;
if(i=3) then
idata<=data;
end if;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end architecture ;
Thank you
you cannot declare an array type inside a port declaration. It will need to be in a package
