Hi everybody !
I want to add(xor) data with CD in shape array and the result would be S Can you help me correcting this code :library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cdm is
port (
clk : in std_logic ;
rst : in std_logic ;
data: in std_logic ;
odata: out std_logic ;
CD : in std_logic_vector(15 downto 0) ;
isis :out integer range 0 to 3 ;
S :out std_logic_vector(3 downto 0 ));
end entity ;
architecture beh of cdm is
type tab is array(3 downto 0)of std_logic_vector(15 downto 0);
signal i :integer range 0 to 3 ;
signal idata :std_logic ;
signal itab :tab ;
begin
code :process(clk,rst)
begin
if(rst='1')then
itab(i)<="0000" ;
else
if(clk'event and clk='1')then
itab(i)<= not(CD(15 downto 12)xor (data));
S(i)<=itab(i);
i<= i+1 ;
itab(i)<=not(CD (11 downto 8) xor(data));
S(i)<=itab(i);
i<=i+1 ;
itab(i)<=not( CD(7 downto 4) xor (data));
S(i)<=itab(i);
i<=i+1;
itab(i)<=not( CD(3 downto 0) xor (data));
S(i)<=itab(i);
i<=i+1 ;
if i=3 then
idata<=data ;
end if ;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end architecture ;
Thank you in advance for your answer
What is the problem?
I think, your i signal is never assigned a value. You're missing a loop or something like that to assign a value to i to begin with. Also itab is always assigned the last value. I suggest you think about the code a little more.- Mark as New
I suggest:
inside clocked process if reset then i <= 0; ... i <= i+1; case i is when 0 => s(0) <=not(CD(15 downto 12)xor (data)); when 1 => s(1) <= ...; when 2 => when 3 =>- Mark as New
corrected S
inside clocked process if reset then i <= 0; ... i <= i+1; case i is when 0 => s <=not(CD(15 downto 12)xor (data&data&data&data)); when 1 => s <= ...; when 2 => when 3 =>- Mark as New
You want that I make like that :
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity cdm is --generic ( -- width : natural :=4); port ( clk : in std_logic ; rst : in std_logic ; data: in std_logic ; odata: out std_logic ; CD : in std_logic_vector(15 downto 0) ; isis :out integer range 0 to 3 ; S :out std_logic_vector(3 downto 0 )); end entity ; architecture beh of cdm is --type tab is array(3 downto 0)of std_logic_vector(15 downto 0); signal i :integer range 0 to 3 ; signal idata :std_logic ; --signal itab :tab ; begin code :process(clk,rst) begin if(rst='1')then i<="0000" ; else if(clk'event and clk='1')then i<=i+1 ; case i is when 0 =>s(0)<=not(CD(15 downto 12) xor (data)); when 1 =>s(1)<=not(CD(11 downto 8) xor (data)); when 2 =>s(2)<=not(CD(7 downto 4) xor (data)); when 3 =>s(3)<=not(CD(3 downto 0) xor (data)); if i=3 then idata<=data ; end if ; end case ; end if ; end if ; end process ; isis<=i; odata<=idata ; end architecture ; ?? ! Thank you in advance- Mark as New
try this
if(rst='1')then
i <= 0 ;
elsif(clk'event and clk='1')then
i <= i + 1 ;
case i is
when 0 => s <= not(CD(15 downto 12) xor (data&data&data&data));
when 1 => s <= not(CD(11 downto 8) xor (data&data&data&data));
when 2 => s <= not(CD(7 downto 4) xor (data&data&data&data));
when 3 => s <= not(CD(3 downto 0) xor (data&data&data&data)); odata<=data ;
end case ;
end if ;
end process ;
end architecture ;
I thank that it is necessary to leave the 1st program and inside it will be necessary to make out a will "data" (1 or 0)
non ?- Mark as New
--- Quote Start --- I thank that it is necessary to leave the 1st program and inside it will be necessary to make out a will "data" (1 or 0) non ? --- Quote End --- I don't think even "Tricky" can understand your post. Why don't you just simulate and adjust things. That is how we all work and learn. write compile simulate and repeat cycle
There are some errors :
Error (10381): VHDL Type Mismatch error at cdmoin.vhd(34): indexed name returns a value whose type does not match "std_ulogic", the type of the target expression Error (10327): VHDL error at cdmoin.vhd(34): can't determine definition of operator ""&"" -- found 0 possible definitions ?!- Mark as New
--- Quote Start --- I don't think even "Tricky" can understand your post. Why don't you just simulate and adjust things. That is how we all work and learn. write compile simulate and repeat cycle --- Quote End --- I'm sorry but I don't well understood !
You didnt copy Kaz's code properly. It compiles just fine for me.
Like Kaz said - why not try and learn the code yourself, rather than have someone do it for you?- Mark as New
is that error in this file or another? also as a sidenote, putting your code in code tags improves readability.
hi guys !!
i solved my problem but i have another is near of ""Type Re is array "" can you help me please !! """" library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity cdma_testbipo is port ( clk : in std_logic ; rst : in std_logic ; data: in std_logic ; odata: out std_logic ; type Re is array(0 to 3)of integer range 0 to 15; signal CD: Re ; isis :out integer range 0 to 3 ; S :out integer range -8 to 7 ); end entity ; architecture beh of cdma_testbipo is type RAM is array (0 to 3) of integer range -8 to 7; signal i :integer range 0 to 3 ; signal code : RAM; signal idata :std_logic ; begin code(0)<=CD(15 downto 12); code(1)<=CD(11 downto 8) ; code(2)<=CD(7 downto 4) ; code(3)<=CD(3 downto 0) ; bpsk :process(clk,rst) begin if(rst='1')then i<= 0; else if(clk'event and clk='1')then i<=i+1 ; if(idata='0') then s<=-code(i); else s<=code(i); end if; if(i=3) then idata<=data; end if; end if ; end if ; end process ; isis<=i; odata<=idata ; end architecture ; """"" Thank you- Mark as New
you cannot declare an array type inside a port declaration. It will need to be in a package
