17256 Discussions
[Arria V] ALTPLL: how to use second counter output
I'm still new in using the Quartus II software. May I know how to select/use the second counter output for pll from the Megawizard Plug-In Manager?
Prompt reply from you guys would be greatly helpful. Thanks!
There is a check-box "use this clock" that you must select to enable the second (or 3rd/4th etc.) output.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
I'm sorry but in which tab is the check-box? I'm using version 15.1 by the way...
And may I know whether the "Output Clock" in the General tab is consider as the counter output?
Thanks!
Under the tab "3) output clocks" => select "clk c1" => "use this clock". Tick this box
https://www.alteraforum.com/forum/attachment.php?attachmentid=12005
Cheers,
Alex
Hi Alex,
I think they've change the Megawizard GUI in 15.1. Am assuming c0 = outclk0, c1 = outclk1 and so on...
https://www.alteraforum.com/forum/attachment.php?attachmentid=12015
Indeed, different GUIs for different families (I hadn't spotted Arria V in your tittle).
Under 'output clocks', use the drop down menu next to 'number of clocks'. Select how many you want.
Cheers,
Alex
